Our Client want s his own IP segment AS
David Kondicz
i need to solve this problem. Oru client has own AS with IP range.
We are connected into interface exchange centre with L3 Switch Catalyst 3550. On this switch we have configured own IP range with our AS.
How can i solve this problem with this device?
Make BGP neighbor with clients BGP router and set up his his range to interface?  His BGP router is in different country.
Thanx a lot for help!
Dave
5 Replies 5
paolo bevilacqua
This seems a normal BGP configuration, are you able/certfied to configure BGP ?
NoI am not.
But i think if someone write me the steps how to configure this solution it will be ok. I configured actual reouter too.
I thik first step will create neighbor with router that is in different country.  Add it to the same group?
after that add their IP tho the same interface there is our radnge added
Thanx
Dave
NoI am not.
Honestly it may be a little more complicated than that. Furthermore your use of terminology (add ip range to interface, our group) is not standard and make me wonder if you have the necessary complete understanding of the issue. To avoid potential disruption I would recommend you escalate this to a senior network engineer within your organization, or an external consultant.
David Kondicz
Can you or someone try to explein me please how to config this solution or something that helps me understand it?
I have 3 interfaces used on my L3 switch
1 - Connection into peering centre
2 - oultand connectivity
3 - routed connectivity - my uplink
Anybody?
