Output errors on Ethernet interface
jalexan
Good day,
I am seeing ouput errors on a half duplex interface facing a comtrend modem.
What could be causing this? I'm not seeing any other errors besides collisions which are normal for half duplex.
paolo bevilacqua
Which output errors? Send the complete show interface.
Ethernet1 is up, line protocol is up
Hardware is PQUICC_FEC, address is 0011.20da.dcb1 (bia 0011.20da.dcb1)
Internet address is
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, 10Mb/s
Last input 00:00:10, output 00:00:00, output hang never
Last clearing of "show interface" counters 19:14:45
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 2000 bits/sec, 3 packets/sec
204404 packets input, 176145912 bytes, 0 no buffer
Received 1374 broadcasts, 0 runts, 0 giants, 0 throttles
164757 packets output, 29247181 bytes, 0 underruns
1301 output errors, 1844 collisions, 0 interface resets
9 lost carrier, 0 no carrier
That should be "excessive collisions", check "show controllers ethernet 1".
