Overlap fragment on 3845 Router
juda.barnes
I am looking for example of ACL to deny overlap fragments,
i have 3 messages on a router 3845 ,   follow cisco documentation it might be an attack on a host
the recommandation  was to  create an ACL to deny overlap,
Can someone please put an example of such ACL,  many thanks
.Jun 25 07:35:49.097: %IP_VFR-3-OVERLAP_FRAGMENTS: GigabitEthernet0/0: from the host 183.216.33.100 destined to xx.xx.205.102
.Jun 25 07:35:49.101: %IP_VFR-3-OVERLAP_FRAGMENTS: GigabitEthernet0/0: from the host 183.216.33.100 destined to xx.xx.205.102
.Jun 25 07:36:29.566: %IP_VFR-3-OVERLAP_FRAGMENTS: GigabitEthernet0/0: from the host 183.216.33.100 destined to xx.xx.205.102
http://www.cisco.com/cgi-bin/Support/Errordecoder/index.cgi?action=search&index=all&locale=en&query=%25IP_VFR-3-OVERLAP_FRAGMENTS&counter=0&paging=5&links=reference&sa=Submit
skarthic
If you think that this traffic coming from 183.216.33.100 is an invalid one, you can configure an ACL denying fragments from that particular source.
ACL could be like
access-list deny tcp host 183.216.33.100 host fragments
access-list permit ip any any
This is going deny only fragmented packets from the particular source.
Subramaniya Karthic.R
Rozsa Illes
If you want to deny non-initial fragments via ACL from the above host, you can use:
access-list 101 deny tcp host 183.216.33.100 any fragments
A bit more information via this link:
http://www.cisco.com/en/US/docs/ios/12_2s/feature/guide/fsaclseq.html#wp1046701
At the same time, you might want to check if the fragmentation could happen due to incorrect MSS value set and try to lower it via: "ip tcp adjust-mss".
Warm Regards,
Rose
paolo bevilacqua
With only three messages, I would not worry and do not do anything but monitor.
