overloading an access-group
lcaruso
Level 6
Level 6
On a 1811 running 12.4 I have the following which I have not seen before. The same identifier is used for an access list and a dhcp pool. The only place that identifier is referenced is under a vlan definition. My question: is this access-group statment referring to the access-list or the dhcp pool or both? Does it actually use both?
interface FastEthernet8
switchport access vlan 99
duplex full
interface Vlan99
description Internet Only VLAN
ip address 192.x.x.254 255.255.255.0
ip access-group Internet_Only in
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
ip access-list extended Internet_Only
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 172.16.0.0 0.15.255.255
deny   tcp any host 192.x.x.254 eq telnet
deny   tcp any host 192.x.x.254 eq 22
deny   tcp any host 192.x.x.254 eq www
deny   tcp any host 192.x.x.254 eq 443
deny   udp any host 192.x.x.254 eq snmp
deny   udp any host 192.x.x.254 eq snmptrap
deny   tcp any any eq smtp
permit ip any any
ip dhcp pool Internet_Only
   network 192.x.x.0 255.255.255.0
   default-router 192.x.x.254
   dns-server 208.67.222.222
   lease 0 8
manish arora
Level 6
Level 6
The access-group is just for access-list.
For dhcp , It you dont need any command under the vlan interface , unless the interface itself is getting ip address from another ios dhcp server.
check this link out for more info on DHCP config in IOS.
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html#wp1001297
Manish
manish arora
Level 6
Level 6
Manish
Thanks for the explanation and the link.
