packet loss from isp issue
jkay18041
Level 3
Level 3
I have a internet connection through cox communications, for the past year or more I've had issues with packet loss sometimes it's around 10% and higher but for the most part it's about 1%. I've complained to them over and over and they tell me the issue is not with them. I've ran some trace routes using a linux box and mtr and uploaded the photo to the post. The first host is my router (cisco 2821) the second host is some cox device even though it has a private IP, it is nothing inside my network.
I was hoping someone could take a quick peak at my config and see if there is anything they see that could possibly cause this issue. I don't think Cox is going to be able to help me much as the last tech (a senior tech) told me the issue was my cable modem was plugged into a power strip and the power strip splits the voltage 6 ways causing the cable modem to fail....so given that comment I don't think I will be getting much help on their end.
Building configuration...
Current configuration : 6207 bytes
version 15.1
service password-encryption
hostname Router2821
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.151-4.M12a.bin
boot-end-marker
aaa new-model
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip domain name Home
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ipv6 unicast-routing
ipv6 cef
ipv6 cef accounting per-prefix
ipv6 dhcp pool Cox
prefix-delegation pool Cox-ipv6
dns-server 2001:4860:4860::8888
dns-server 2001:4860:4860::8844
ipv6 inspect name traffic ftp
ipv6 inspect name traffic udp
ipv6 inspect name traffic icmp
voice-card 0
crypto pki trustpoint TP-self-signed-
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-
revocation-check none
rsakeypair TP-self-signed-
crypto pki certificate chain TP-self-signed-
certificate self-signed 01
quit
license udi pid CISCO2821 sn
username admin privilege 15 password 7
redundancy
ip ssh time-out 70
ip ssh authentication-retries 2
ip ssh version 2
class-map type inspect match-any All_Protocols
match protocol tcp
match protocol udp
match protocol icmp
policy-map type inspect Trusted_to_Internet
class type inspect All_Protocols
inspect
class class-default
drop
zone security Trusted
zone security Internet
zone-pair security Trusted->Internet source Trusted destination Internet
service-policy type inspect Trusted_to_Internet
interface GigabitEthernet0/0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ipv6 address dhcp
ipv6 address autoconfig default
ipv6 enable
ipv6 nd autoconfig default-route
ipv6 verify unicast reverse-path
ipv6 dhcp client pd hint ::/60
ipv6 dhcp client pd Cox-ipv6
ipv6 inspect traffic out
ipv6 traffic-filter wan-in in
ipv6 traffic-filter wan-out out
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
description LAN
encapsulation dot1Q 1 native
ip address 10.10.1.253 255.255.255.0
ip nat inside
ipv6 address Cox-ipv6 ::/64 eui-64
ipv6 enable
ipv6 nd other-config-flag
ipv6 dhcp server Cox
interface GigabitEthernet0/1.2
description Wireless
encapsulation dot1Q 2
ip address 192.168.2.254 255.255.255.0
ip access-group wifi_block in
ip access-group wifi_block out
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip route 10.28.0.0 255.255.255.0 10.10.1.249
ip route 10.29.0.0 255.255.255.0 10.10.1.249
ip route 10.30.0.0 255.255.255.0 10.10.1.249
ip access-list extended NAT
deny ip 10.10.1.0 0.0.0.255 192.168.2.0 0.0.0.255
deny ip 192.168.2.0 0.0.0.255 10.10.1.0 0.0.0.255
permit ip any any
ip access-list extended wifi_block
permit ip any any
ip sla 1
http get http://freedns.afraid.org/dynamic/update.php
frequency 120
ip sla schedule 1 life forever start-time now
access-list 122 deny tcp any eq 22 any
access-list 122 permit tcp 10.0.0.0 0.255.255.255 any
snmp-server community fast_stats RO
snmp-server host 10.10.1.249 version 2c
ipv6 access-list wan-in
permit icmp any any
permit udp any any eq 546
permit tcp any any established
sequence 100 deny ipv6 any any
ipv6 access-list wan-out
permit icmp any any
permit tcp any any
permit udp any any
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
access-class 122 in
privilege level 15
password 7
transport input ssh
scheduler allocate 20000 1000
end
I just want to make sure I don't have something goofed up on my end before I point the finger anymore at Cox.
Thank you for the help and input.
16 Replies 16
I have run some ping tests, and a few packets are lost intermittently. As said, ICMP traffic usually has the lowest priority in provider networks, so losing some doesn't necessarily mean you have a network problem.
Did adjusting the buffers get rid of the ignored packets ? Are your users experiencing slow connectivity ?
The buffers you gave me seemed to of got rid of the errors on that.
As far as the packet loss goes I still have it but I finally was able to talk to someone I know at the ISP and they forwarded my traceroutes with the packet loss onto someone who was able to see some issues on the node. I was told they would monitor my cable modem and look into the noise issue on the node.
As far as slow connectivity the download speed is usually ok but uploads are just painful especially when the packet loss is higher. I'm sure this will all go away once they figure out where the issue is.
Thank you again for all your help!
