Hi Community,
I have a question, I have been experienced packets lost in LAN, my question is when I ping the dest with 100 repetitions for example I dont get any packet lost but if I ping the destination with 500 repetitions always I get some packets lost (1 or 2).
Note: I can ping the host with 100 rep several times but I never got any packet lost.
Core# ping 10.32.103.194 count 100
--- 10.32.103.194 ping statistics ---
100 packets transmitted, 100 packets received, 0.00% packet loss
round-trip min/avg/max = 0.505/1.266/10.758 ms
Core# ping 10.32.103.194 count 500
500 packets transmitted, 499 packets received, 0.20% packet loss
round-trip min/avg/max = 0.551/1.283/14.304 ms
This make sense for you?
Have you ever had this kind of issue?
--- Sorry for my english.
Solved! Go to Solution.
Hi Omar,
Because ping packets are of low priority and CPU can drop it for any reason that it can't serve a ping request.
Apart from ping packet loss what issue you have? If you have packet loss while your hosts are trying to talk to each other then it is a concern that needs to be looked at. Depending on the platform there are rate-limiters that can drop such packets. So I would see this as normal unless you have any other issues due to this.
Madhu
Hi Omar,
Madhu
One difference, if I remember correctly, Cisco devices use ICMP pings while (Windows) PCs use UDP pings.
