Packet tracer: Routers wont ping when connected to switch 0
onet12
I am working on part of an assignment and I am trying to ping 2 routers. They will not ping if connected to switch 0, but will ping if connected to switch 1. What am I missing? Attached is the PT file of a smaller example of what I am working with.
onet12
PT File here
you cannot use 192.0.0.0/24 for both LANs (overlapping), if you are planning to connect them. check your assignment again, sometimes they gives IP address plan
Good luck
KB
