GRE Tunnel
arunkumarravi
IP add of VPC1 is 192.168.1.10 , VPCS 2 is 192.168.2.10
GRE tunnel is configured between R3 and R4.
Tunnel is up and I am able to ping the VPC2 from VPC1 and vice versa, however if I take a capture I couldn't able to see the Tunnel IP being encapsulated.
you need these two command.
R3
ip route 192.168.1.0 255.255.255.0 184.50.255.193
REMOTE router
ip rotue 192.168.2.0 255.255.255.0 184.50.255.192
note:- in mid router you dont need these static route
S 192.168.1.0/24 [1/0] via 4.15.133.218
S 192.168.2.0/24 [1/0] via 23.50.138.134
12 Replies 12
capture do you use filter ?
No I didn't use any filter.
Other than ICMP no other traffic is generated.
what software you use eve-ng or CML ?
I am using eve-ng
Problem is not the filter or wireshark, I can see the ICMP packets from wireshark but not the actual encapsulated IP.
Ok,
share the config I will check it
what I suspect you mistake config the static route
ip route x.x.x.x y.y.y.y <tunnel destination>    <<<-- this wrong
you need
ip route x.x.x.x y.y.y.y <tunnel IP>     <<<- this is right
the static route to remote peer tunnel IP end shift the traffic to enter the tunnel.
Yeah that's right. may be the route issue.
let me change and check
R3
REMOTE router
Thanks , it is resolved now.
you are so welcome
Can you also suggest me how to achieve this with the help of BGP(Instead of static route)
