packets ignored on T1
sarah12345
What problem does it indicate when the input packets are ignored? I know that indicates the hardware runs low on internal buffers. Does it indicate a hardware issue? How do I check sanity of the hardware (it's a CHOC12).
#show inter Se7/0/0.6/25:1
Serial7/0/0.6/25:1 is up, line protocol is up
Hardware is C10K CHOC12 One Port
56807623 input errors, 0 CRC, 0 frame, 0 overrun, 56807623 ignored, 0 abort <=== ignored
Sarah
paolo bevilacqua
Over which period of time you had this, what is the total input counters, and are the "ignored"still increasing ?
Hi Paolo,
The interface stat was never cleared, but I retrieved it every second for a few seconds, and the ignored count keeps on increasing.
62328836 packets input, 1208172224 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
401875038 packets output, 3628945171 bytes, 0 underruns
0 carrier transitions no alarm present
Timeslot(s) Used: 1-24, subrate: 1536Kb/s, transmit delay is 0 flags
non-inverted data
Sarah
Not sure if user on that circuit are complaining but if the error counter is correct, they should because they amount to like 80%.
Now one should look at all this box entirely because such an high rate of "ingore" is not normal.Since it is an high-end router and you likely have a support contract, I suggest you contact the TAC where there are specialized teams for this kind of problems.
Hi Paolo,
Thanks, I'll contact TAC.
Sarah
