Particular application has to be given limited bandwidth by using QOS
I want to limit the bandwidth one of the particular application in my router by using QOS and I have configured the QOS  but It is not working as I need.
Please find the below configuration and suggest.
1.SMTP sholud not take more than 20 k whereas as per below configuration,each conversation it takes below 20 k.
For example.
A. 2.2.2.2/24 to 4.4.4.4/24--------------19 k bandwidth
B.2.2.2.3/24 to 4.4.4.5/24----------------15 K bandwidth
Configuration
class-map match-all SMTP
match protocol smtp
Policy-map qostest
class SMTP
shape average 20000
int g0/0
service-policy output qostest
please check the above config and suggest that how to limit the bandwidth all the conversation should not exceed 20k
Hello
When your shaping your really shouldn't see much drops as shaping queues traffic so as not to drop it, so clear your interface counters just to make sure your not seeing historic rates.
Also having an load interval of 5 minutes wont really give you a good representation of the actual traffic rate, so suggest also to decrease this for testing purposes and review again
Saying that if you wish to allow only 19K to smtp try the below config.
access-list 100 permit tcp host 2.2.2.2 host 4.4.4.4 eq 25
access-list 101 permit tcp host 2.2.2.3 host 4.4.4.5 eq 25
Class-MAP 2-4
match access-group 100
Class-MAP 3-5
match access-group 101
policy-map qostest
class 2-4
Bandwidth 19
class 3-4
Bandwidth 19
class class-default
fair-queue
clear counter x/x
int x/x
load interval 30
res
Paul
Kind Regards
Paul
8 Replies 8
Julio E. Moisa
What you see through: show policy-map interface g0/0
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Please find the my results.
I could see in my router,whatever bandwidth limited,whereas my whatsup gold is not showing properly.Instead it is showing each conversation 20k limitation.
Router#sh traffic-shape queue g0/0
Traffic queued in shaping queue on GigabitEthernet0/0
 Traffic shape class: SMTP
  Queueing strategy: weighted fair
  Queueing Stats: 2/1000/64/0 (size/max total/threshold/drops)
     Conversations  2/3/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 20 kilobits/sec
  (depth/weight/total drops/no-buffer drops/interleaves) 1/32384/0/0/0
  Conversation 1, linktype: ip, length: 74
  source: 17x.17.x.x, destination: 172.1x.x.x, id: 0x3101, ttl: 123, prot: 1
  Conversation 15, linktype: ip, length: 1514
  source: 172.x.x.x, destination: x.x.x.x, id: 0x7F51, ttl: 255, prot: 1
Router#sh policy-map int g0/0
  Service-policy output: qostest
    Class-map: SMTP (match-all)
      34455 packets, 3670268 bytes
      5 minute offered rate 10000 bps, drop rate 1000 bps
      Match: protocol smtp
        5 minute rate 10000 bps
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
             20000/20000      2000   8000      8000      1000      1000
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      68        29516     3077210   28238     2942052   yes
    Class-map: class-default (match-all)
      79080 packets, 11898751 bytes
      5 minute offered rate 24000 bps, drop rate 0 bps
      Match: all
Actually I think your shaping is working:
Not sure why WhatsUp Gold is showing the per flow limitation...
Your stats indicate shaping is working. In fact, the posted stats show shaping active, 68 packets currently queued, and packets have been delayed.
I suspect your What's up Gold is "confused" by the QoS policy and is incorrectly showing the shaping per conservation.
Hello
Class-MAP 2-4
Class-MAP 3-5
policy-map qostest
class 2-4
Bandwidth 19
class 3-4
Bandwidth 19
class class-default
fair-queue
clear counter x/x
int x/x
load interval 30
res
Paul
Kind Regards
Paul
Thank u Paul Driver for your reply.
I want to limit entire smtp should be limited 20k,whoever passing through this link.(router int g0/0)
Moreover, is it required these commands,please explain.
class class-default
fair-queue
hello
Amend the acl to accommodate any traffic
ip accces-list extended 100
no 10
no 20
10 permit tcp any any eq 25
class class-default
fair-queue
Fair queue (WFQ) is for your traffic which cannot or has not been characterize in any class map and is left to use the default queue ( class-default) where it can allocated some fairness of BW to the default traffic queue
res
Paul
Kind Regards
Paul
I lost track of the entire thread, but your initial configuration is working. The problem seems to be the way WhatsUp Gold is reporting and displaying the flows. Can you maybe provide a screenshot of the relevant WhatsUp Gold information that is being collected ?
