10-04-2013 08:54 PM - edited 03-04-2019 09:14 PM
I am trying to find a good way to one-to-one NAT certain private addresses that are already permitted in a overload from the same pool used by PAT.
e.g.
access-list 5 permit 10.1.1.0 0.0.0.255
route-map Map-5
match ip address 5
ip nat pool pool-5 1.1.1.1 1.1.1.6 netmask 255.255.255.248
ip nat inside source route-map Map-5 pool pool-5 overload
ip nat inside source static 10.1.1.5 1.1.1.5
Would such a configuration work? Would that allow 10.1.1.5 to always use 1.1.1.5 but still do normal PAT for the other private and public addresses?
Solved! Go to Solution.
10-05-2013 12:35 AM
Hello
access-list 5 deny 10.1.1.5
Res
Paul
10-05-2013 12:35 AM
Hello
Res
Paul
