pause output and SIP
charlesegibbs
I have an 1841 as an edge router for a office of around 50 users. We are using a cloud SIP solution for voice only. We have been experieincing call quality issues and looking at the interface that is connected to our ISP I see pause output incrementing, could this be a cause for call quality to be an issue? The circuit is 100Mbs fiber handoff.
The counters were cleared 12 hours prior to this:
GigabitEthernet0/1/0 is up, line protocol is up
  Hardware is PM-3387, address is 0025.846b.e132 (bia 0025.846b.e132)
  Internet address is 64.125.118.234/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is autonegotiation, media type is ZX
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 17:58:41
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2785000 bits/sec, 689 packets/sec
  5 minute output rate 731000 bits/sec, 669 packets/sec
     13157925 packets input, 2864181448 bytes, 0 no buffer
     Received 52 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     10558731 packets output, 2394745206 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 2356 pause output
Thanks!
paolo bevilacqua
You can agree with ISP to configure flow-control to be off.
That is not said will fix any voice quality issue (I believe it will not), again it's your ISP responsability to investigate.
