VRFs not working properly between core routers
Islam Nadim
Hello All,
     I have this problem when I'm working with VRFs on GNS3 ..
     If I have only 1 core router, the VRF works fine. But when I add another Core router, the VRF doesn't work
NOTE: I'm using 2691 routers.
This is the topology that works:
And this is the one that doesn't work:
This is the VRF configuration on both Core routers:
Core1:
ip vrf C1
rd 100:1000
route-target export 100:1000
route-target import 100:1000
ip vrf C2
rd 200:2000
route-target export 200:2000
route-target import 200:2000
Core2:
ip vrf C1
rd 100:1000
ip vrf C2
rd 200:2000
Need advise
12 Replies 12
do you have a vpnv4 neighbor relation ship established between core 1 and core2.
if you want communication between all the routers then the rds must be impoted accordingly. Hope u understood.
Please rate the post if it is informative.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
I'm using static routes .. sorry for not stating that earlier
Do you mean PE-CE rpotocol is static routing.
What about PE-PE protocol, is it also a static routing.
In your second case you must have a way to deliver your vpn routes to other core routers. You can achieve this by MPBGP or in your static routing case you must be able to play with tunneling.
I mean define two tunnels between two core routers, place each of them in different vrfs, I am not sure but it must work.
Thanveer
Everything is running static .. I'm using static just for the sake of testing ...
So as I understood, I should use tunnels between the PEs? Can you show me how?
Ajay Raj
If you are using VRF, then PE to PE should be MPBGP otherwise it wont work.
Hello Islam,
You do not need to tun MPBGP, as you said, you have configured static routing, I think that will be problem, could you post configuration of both Core routers.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
here are the config:
Core1:
version 12.4
hostname Core1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf C1
rd 100:1000
ip vrf C2
rd 200:2000
no ip domain lookup
ip domain name lab.local
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
description -- UNUSED --
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
description to Core2
ip address 192.168.0.1 255.255.255.0
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
description to A1
ip vrf forwarding C1
ip address 192.168.2.1 255.255.255.0
clock rate 2000000
interface Serial0/2
description to B1
ip vrf forwarding C2
ip address 192.168.4.1 255.255.255.0
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Serial0/0
ip route vrf C1 0.0.0.0 0.0.0.0 Serial0/0
ip route vrf C2 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Core2:
version 12.4
hostname Core2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf C1
rd 100:1000
ip vrf C2
rd 200:2000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
description to Core1
ip address 192.168.0.2 255.255.255.0
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
description to A2
ip address 192.168.3.1 255.255.255.0
clock rate 2000000
interface Serial0/2
description to B2
ip address 192.168.5.1 255.255.255.0
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
As for the CE routers, only the Serial0/0 interfaces configured with the appropriate IPs, and a static default route pointing to the Serial0/0
If all you want to achieve is to extend your VRFs to Core2 without inter-VRF-communication than VRF lite is the way to go. Basicly all you have to do is create subinterfaces on s0/0 and assign these subinterfaces to their respective VRF. Remember that you could technically use identical IP-adresses / subnets on all subinterfaces, as these remain within each VRF.
If you need inter-VRF-connectivity than MP-BGP is needed. The tunnel construction already mentioned might work, but I have never seen that or tested myself so I don't know for sure.
Regards.
Any config samples would be great
Hello Nadeem,
Here is your configuration, I was planning to do a test scenario, however you helped me out to learn and show this.
Please find the scenario and the attachments.
Please rate the post and mark it answered if you feel it answered.
Thanveer
As pille said, if you use vrf-lite you need to connect Core1 and Core2 with links in respective VRFs. VRF is local to both routers and you connected them with link S0/0 <-> S0/0 in global routing table.
Solution ->
1) create second link between Core1 and Core2, existing link will be added to first VRF and new link to second VRF, that way each vrf can communicate via restective link.
2) leave configuration as it is and create two GRE tunnels via existing link, one tunnel for one VRF.
Core1
interface Tunnel 1
ip address 10.0.0.1 255.255.255.0
tunnel source s0/0
tunnel destination 192.168.0.2
interface Tunnel 2
tunnel source s0/0
Core2
interface Tunnel 1
ip address 10.0.0.2 255.255.255.0
tunnel source s0/0
tunnel destination 192.168.0.1
interface Tunnel 2
tunnel source s0/0
Traffic from particular VRFs will be transported between Core1 and Core2 thanks to GRE tunnels. Do not forget to configure static routing to work this properly.
Best Regards
