PBR and VTI IPSEC
Hi we are trying to configure PBR with VTI as next-hop interface or ip address, but with no luck.
we see that traffic is matching the PBR and ACL and indeed the traffic is returned according to the statistics of show crypto ipse sa peer x.x.x.x but no get the host response (ping test)
According to this document of nexus is not supported
Configuring Policy Based Routing (cisco.com)
this is the actual config
ip dhcp pool CLIENT_21
host 192.168.3.21 255.255.255.0
hardware-address f832.e4bd.f22a
ip access-list extended LAN-TO-LAN2
permit ip host 192.168.3.21 192.168.10.0 0.0.0.255
deny ip any any
route-map PERIFERIA-RM permit 1
match ip address LAN-TO-LAN2
set interface Tunnel10
interface Vlan1
ip policy route-map PERIFERIA-RM
balaji.bandi
what is the device you using to configure ?
what is the configuration of vlan 1
can you post show run interface vlan1 and show ip route
BB
7 Replies 7
balaji.bandi
BB
Hi thanks for the replay,.
Cisco C881-K9 - IOS 15.4(1r)T2 with advsecurity
what is the configuration of vlan 1?
IOSFW1#show running-config interface vlan 1
Building configuration...
Current configuration : 228 bytes
interface Vlan1
description INSIDE
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip verify unicast source reachable-via rx
zone-member security INSIDE
end
IOSFW1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, Dialer111
169.254.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 169.254.255.0/30 is directly connected, Tunnel10
L 169.254.255.2/32 is directly connected, Tunnel10
172.17.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.17.1.0/24 is directly connected, Loopback0
L 172.17.1.1/32 is directly connected, Loopback0
181.128.0.0/32 is subnetted, 1 subnets
C 181.128.88.95 is directly connected, Dialer111
190.248.0.0/32 is subnetted, 1 subnets
C 190.248.0.245 is directly connected, Dialer111
192.168.3.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.3.0/24 is directly connected, Vlan1
L 192.168.3.1/32 is directly connected, Vlan1
IOSFW1#show route-map
route-map PERIFERIA-RM, permit, sequence 1
Match clauses:
ip address (access-lists): LAN-TO-PERIFERIA
Set clauses:
interface Tunnel10
Policy routing matches: 118 packets, 10250 bytes
IOSFW1#show access-list LAN-TO-PERIFERIA
Extended IP access list LAN-TO-PERIFERIA
10 permit ip host 192.168.3.21 172.168.10.0 0.0.0.255 (118 matches)
20 deny ip any any log (295094 matches)
I was just about to ask you for the full running configuration, as there is a Zone Based Firewall involved, which can complicate matters, but I see that the issue has been resolved. Just out of curiosity, how did you resolve this ?
the problem was the command ip verify configured in tunnel 10 interface
IOSFW1#show running-config interface tunnel 10
Current configuration : 327 bytes
interface Tunnel10
description VPN1
ip address 169.254.255.2 255.255.255.252
ip nat inside
zone-member security VPN
tunnel source Dialer111
tunnel mode ipsec ipv4
tunnel destination X.X.X.X
tunnel protection ipsec profile VPN1-PROFILE
end
hi thanks,
great, thanks for sharing the solution !
Hello
That's strict unicast reverse path forwarding (uRPF) and what the rtr does when that’s applied is to check its own routing table against the source address of the packet it has just received and if it finds a match but the interface of that packet source address is different as to the interface it was received on then the rtr will drop that packet..
Kind Regards
Paul
