PBR for Multiple Natting
m.salah
I have one router (ISR 3845) having a multiple serial and ATM connections for different services, each service has it is own NAT.(Inside on the Ethernet side and out on serial and ATM interfaces)
My question is: how I can configure the multiple NATs on one router only, using PBR or any other technologies.
vijayasankar
Level 4
Level 4
To acheive the same you need to use NAT along with Route-maps.
Check the following URL for more information on this.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087bac.html#1026010
Hope this helps, if so please rate the post.
-VJ
rohit_agarawal
y au can do with pbr
this is the example :-
access-list 101 permit ip 192.168.5.6 0.0.0.0 any
access-list 102 permit ip 192.168.5.0 0.0.0.255 any
route-map permit 20
match ip address 101
match interface Serial0
route-map permit 30
match ip address 102
match interface Serial1
ip nat inside source route-map nats0 interface serial0 overload
ip nat inside source route-map nats1 interface Serial1 overload
try i will work
can u tell me ur exact requirment
mahmoodmkl
Level 7
Level 7
