PBR for redirecting HTTP Traffic
Hi Gurus,
Can you pls. check if this is correct, i want to redirect http request to my L4 and caching servers.
access-list 110 deny   tcp any any neq www
access-list 110 deny   tcp host 202.X.X.2 any
access-list 110 permit tcp any anywww any
route-map HTTP-TRAFFIC permit 10
match ip address 110
set interface GigabitEthernet4/1
set ip next-hop 202.X.X.2
interface FastEthernet3/4
description **To Test Client**
ip address 202.x.x.13 255.255.255.248
ip policy route-map HTTP-TRAFFIC
end
tia
Giuseppe Larosa
Hello Jepoy,
configuration looks like correct, but I would suggest you to investigate also WCCP if supported on your router and on the cache engine.
It is a more specific tool for diverting HTTP traffic to web cache and allows router to detect web cache failures
Hope to help
Giuseppe
Marwan ALshawi
change your conifg to be like bellow:
use one of the following lines only
if you want to consider http reply ( almost this wil be from the web server to the requesting client )
access-list 101 permit tcp any eq www any
if you want http request use:
access-list 101 permit tcp any any eq www
match ip address 101
about the interface:
yo need to apply it to the inbound interface ( the interface where the traffic sourced from )
i think you were using the exit interface and in this case will not work
good luck
if helpful Rate
Hi guys,
My first setup would be like this
clients---6500 --- redirecting http request ---- L4 switch --- cascading caching servers
Im not seeing any packet counters on my route-map. I want to check if theres a problem on my pbr or on the L4. The route-policy is applied ingress coming from my clients. Also can the route-map also applies to vlan interface?
6500#sh access-lists 110
Extended IP access list 110
    deny tcp any any neq www (18 matches)
    deny tcp host 202.x.x.2 any
    permit tcp any any
6500#sh route-map HTTP-TRAFFIC
route-map HTTP-TRAFFIC, permit, sequence 10
  Match clauses:
    ip address (access-lists): 110
  Set clauses:
    ip next-hop 202.x.x.2
  Policy routing matches: 0 packets, 0 bytes
If i use wccp then do i need to use the L4? or may be the L4 would be use for the wccp, any suggestions?
tia.
Jeff
Hello Jepoy,
Marwan is right: the PBR has to be applied inbound on client vlans, anyway  on interface(s) that receives traffic to be redirected.
has to be:
clients--PBR -6500 --- ---- L4 switch --- cascading caching servers
about WCCP : you need to verify that web engines support it and yes it is an alternative to the use of the L4-L7 switch load balancer
Hope to help
Giuseppe
