PBR is not functioning on 2901 G2 router
I have one router 1841 in which i configured PBR for internet traffic from LAN. I hv two ISPs few server are configured for ISP1 and few for ISP2.I planned to shift my existing setup at 2901 G2 router. when I am configuring the same config on this router so traffic is passing through only from one ISP not from other, if I troubleshoot so I see that the interface which is connected with ISP2 is not getting any input/output packet.
Kindly advise......
Config is here:
interface FastEthernet0/0
description ****** ISP2 ******
ip address 203.xx.xx.110 255.255.255.248
ip access-group blockicmp in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.240
ip nat inside
ip policy route-map zee
duplex auto
speed auto
interface Serial0/0/0:0
description ***** ISP1 ******
ip address 221.xx.xx.82 255.255.255.252
ip nat outside
ip nat inside source list Link-1 interface Serial0/0/0:0 overload
ip nat inside source list Supernetlink interface FastEthernet0/0 overload
ip nat inside source static 192.168.1.11 203.xx.xx.106
ip nat inside source static 192.168.1.4 203.xx.xx.107
ip access-list extended Link-1
permit ip host 192.168.1.13 host 221.xx.xx.81
permit ip host 192.168.1.6 any
ip access-list extended Supernetlink
permit ip host 192.168.1.13 host 203.xx.xx.105
permit ip host 192.168.1.13 host 203.xx.xx.3
permit ip host 192.168.1.13 host 203.xx.xx.4
ip access-list extended test_L1
permit ip host 192.168.1.2 any
permit ip host 192.168.1.14 any
permit ip host 192.168.1.7 any
permit tcp host 192.168.1.1 eq 7778 any
permit ip host 192.168.1.10 any
ip access-list extended test_SUPER1
permit ip host 192.168.1.8 any
permit tcp host 192.168.1.11 eq smtp any
permit tcp host 192.168.1.11 any eq smtp
permit tcp host 192.168.1.11 any eq domain
permit ip host 192.168.1.11 any
permit tcp host 192.168.1.5 eq 7778 any
permit tcp host 192.168.1.12 eq ftp-data any
permit tcp host 192.168.1.12 eq ftp any
permit tcp host 192.168.1.12 eq www any
permit tcp host 192.168.1.12 eq domain any
permit ip host 192.168.1.12 any
permit icmp host 192.168.1.13 host 203.xx.x.3
permit icmp host 192.168.1.13 host 203.xx.x.4
permit ip host 192.168.1.4 any
route-map zee permit 10
match ip address test_L1
set ip next-hop 221.120.202.81
route-map zee permit 20
match ip address test_SUPER1
set ip next-hop 203.130.2.105
route-map zee deny 30
ip nat inside source static 192.168.1.8 203.xx.xx.108
ip nat inside source static 192.168.1.5 203.xx.xx.109
ip nat inside source static 192.168.1.10 221.xx.xx.138
ip nat inside source static 192.168.1.7 221.xx.xx.139
ip nat inside source static 192.168.1.14 221.xx.xx.140
ip nat inside source static 192.168.1.2 221.xx.xx.142
cadet alain
Are you testing on the router itself or sending traffic from the real machines, in the former case you have to add in global config the command ip local policy route-map zee if you want traffic originated by the router to be policy routed.
Regards.
Alain.
