BGP advertised-routes commend
fabio.marino
Hi all,
I have a doubt.
Scenario is:
R1 -> R2 -> R3
y.y.y.y -> next hop for R2 towards R3
R2 learns the network x.x.x.x with a static route towards R1.
There is then a BGP session between R2 and R3 and I am announcing the network x.x.x.x to R3.
On R2, issuing the command show ip bgp neighbors y.y.y.y advertised-routes | i x.x.x.x I got as output, in the Next Hop column, the value 0.0.0.0.
Why?
Thanks.
Next hop of 0.0.0.0 indicates that this router is doing the originating advertisement. You can also pass routes from other hosts that would have a next-hop of that advertising routers address:
   Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          10.125.100.54            0         32768 i
*> 1.1.1.0/24       10.23.0.2                          50000 215 1 i
*> 2.2.2.0/24       10.23.0.2                          50000 215 1 i
*> 3.3.3.0/24       10.23.0.2                          50000 215 1 i
*> 4.4.4.0/24       10.23.0.2                          50000 215 1 i
*> 10.12.10.0/24  0.0.0.0                  0         32768 i
If we trace the 4.4.4.0 subnet, you'll notice that the originating AS is 1:
215 1
    10.23.0.2 from 10.23.0.2 (172.28.1.2)
      Origin IGP, localpref 100, weight 50000, valid, external, best
So, heading over to the advertising router in 1, you'll see that the 4.4.4.0 subnet has all 0.0.0.0:
*> 1.1.1.0/24       0.0.0.0                  0         32768 i
*> 2.2.2.0/24       0.0.0.0                  0         32768 i
*> 3.3.3.0/24       0.0.0.0                  0         32768 i
*> 4.4.4.0/24       0.0.0.0                  0         32768 i
*> 10.12.0.0/24     0.0.0.0                  0         32768 i
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
sesoerensen
Hi Fabio, would you mind pasting the bgp configs and show output from R2 and R3?
Cheers,
Søren
stephen.stack
Level 4
Level 4
The reason x.x.x.x is in R2's BGP table with a next-hop value of 0.0.0.0 is becuase the x.x.x.x is locally originated via a static route and is advertised into BGP via a network or aggregate command in the BGP configuration. So, you said x.x.x.x is configured as a static route on R2 point to R1, right? So, i assume to you a network statement in BGP to advertise it onto R3.
Stephen
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
- Always vote on an answer if you found it helpful
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Yup your assumption is correct.
Do you have more example in which the next hop is 0.0.0.0? Or is it valid only for locally originated routes?
Thanks.
215 1
HTH,
John
