PBR questions
gongya001
On R1
ip access-list standard PBR-ACL
  permit 10.10.51.0 0.0.0.255
route-map PBR-MAP permit 10
  match ip address PBR-ACL
  set ip next-hop 172.16.13.3
int e0/2
  ip address 10.10.51.1 255.255.255.0
  ip policy route-map PBR-MAP
When I like to access the direct connected subnet on R1, the traffic is sent to R3, then sent back to R1 ---> R6. Anyway to avoid this to get the path R5----> R1-----> R6 ?
2 Accepted Solutions
gongya001
I figured it out.
thanks !!
use an extended access list where you can specify the source AND the destination. If there is no match, the general routing logic will be used:
So.e.g. with the access list below, only traffic destined for 192.168.47.0/24 will be policy routed, if you try to access the directly connected subnet 10.10.61.0/24, it will bypass the route map.
ip access-list 101 permit ip 10.10.51.0 0.0.0.255 192.168.47.0 0.0.0.255
match ip address 101
gongya001
I figured it.
thanks !!
gongya001
I figured it out.
thanks !!
thanks so much !!
