PBR, set ip next-hop recursive
MapleMagician
I'm trying to understand what the
recursive
keyword actually does. I've labbed several scenario's and I seem to get the same result whether the
recursive
keyword is there or not. Can someone explain to me the purpose of this keyword?
Richard Burts
Much of the time in configuring PBR you are sending traffic to a local interface or to a
next hop
that is directly connected (and therefore has an entry in the routing table). Occasionally you might want to send traffic to a
next hop
that is not directly connected (and therefore may not have an entry in the routing table). Using recursive supports forwarding to a remote
next hop
See this doc for additional details:
https://www.cisco.com/en/US/docs/ios/iproute_pi/configuration/guide/iri_prb_rec_next_hop_external_docbase_0900e4b1810fe58b_4container_external_docbase_0900e4b181525fed.html
Rick
Richard Burts
next hop
next hop
next hop
Rick
This is the answer I was looking for. I actually read that article but your explanation helped me understand. Thank you!
I am glad that my explanation helped you understand the solution better. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
M02@rt37
Hello @MapleMagician,
The
command in PBR is used to specify a recursive
next-hop
IP address. This can be particularly useful when you want to perform PBR and forward traffic to a
next-hop
IP address, but that
next-hop
IP address is learned dynamically through a routing protocol.
Best regards
