Pc does not access isp through router 2811
Translator
Community Manager
Community Manager
Hello good night, I am having the following problem, I have a router 2811 in my personal lab and I am trying to put this router connected directly to the isp and my connected machines in 2811.
ISP —> ROUTER 2811 —> PC
Well Router 2811 has port 0/0 configured to receive the isp and this working normal, I can drip the dns from google and even the isp gateway normally through the 2811, there port 0/1 is connected one of my machines and on this port a dhcp was made and it works fine the Pc can get the ip from dhcp normally, but the Pc can not access the isp, on the cmd I can drip the router normally and the router drips the normal Pc, but the Pc does not drip the isp and you don't even have internet access. I had done this before and it worked, but I must have forgotten something, I did some routes to see if it worked, but they didn't work, so please help me in this task. I'm going to send the show running here to you.
ip dhcp excluded-address 192.168.10.254
ip dhcp pool VIVO
network 192.168.10.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.10.254
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1434AHWS
redundancy
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.10.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.15.1
logging esm config
control-plane
6 Replies 6
1. use #ip routing command to enable routing
2. i assume your ISP connected interface as Fa0/0 and you have already received IP via DHCP to interface. check that using #sh ip int bri  command and make sure ip is there.
3. check #sh ip route and verify your default route is available in routing table
4. check pining to 192.168.10.254 and make sure your PC can ping to gateway properly via LAN
Good luck
KB
there are numerous issues with your configuration. What is the IP address you are getting through DHCP ? The easiest would be to configure the routet for NAT. Add the below to your router:
ip nat outside
ip nat inside
Ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.10.0 0.0.0.255
Ashish K
***Please Rate Helpful Responses***
sorry one colleague is mention this point.
No more addition
paul.driver
Hello
In addtion to NAT please change your default static route
no ip route 0.0.0.0 0.0.0.0 192.168.15.1
ip route 0.0.0.0 0.0.0.0  fa0/0 dhcp
Hello
Kind Regards
Paul
