Permanent license to smart licensing
Andrey.A
Hi all,
I need to upgrade router from 16.8.1 to some newer version probably 16.12.x. Because on new IOS versions you need to use smart licensing, my question is what's happening with currently permanent licenses? If router has securityk9 or appxk9  installed and active, when you jump to 16.12. version all license are moved to evaluation period of 90 days. Does the router still has all features like before? I know that I need to do conversion from traditional to smart licensing, and I will do that. Because of some available MW i would like to do upgrade and later complete smart licensing steps (need to set up Satellite and communication), but if router loses security features after upgrade it's no good.
Thank you all in advance,
Andrey
balaji.bandi
You can convert PAK to a smart License for the new version of code 16.12.X mandatory smart License.
(if you have do not have an account, worth contact licese@cisco.com - can help you) - your Router work as expected with RTU License.
here is the video :
https://www.youtube.com/watch?v=EgwlfVTJfag
https://software.cisco.com/web/fw/softwareworkspace/smartlicensing/ssmcompiledhelps/c_Convert_Classic_Licensing.html
BB
Learn how to assign a classic PAK-based license to a Smart Account using Cisco's License Registration Portal (LRP). This step-by-step guide walks you through the entire process, from logging into Cisco Software Central to managing smart and virtual accounts. Gain enterprise-wide visibility for ...
Andrey.A
Hi @balaji.bandi thank you for reply. Just quick question. After you register device with smart account, you don't need to perform any additional configuration? Security and appx license will be automatically authorized by device, correct?
you need to configure on the device to contact the smart License server of the cloud to get register and validation.
BB
