permit specify community to prefix list
Hi Dears
I have Prefix list filter for uplink 1 and uplink 2
Filter out by prefix-list
No my qustion id How used community string in prefix list according the picture if customer
annouce prefix by community 100:1 announce on uplink 1
if announce by comminuty 100:2 announce to uplink 2
Pleas help me ?
Hi admin@atrinnet.net ,
Both route-maps have a match for prefix-list and community-list. The action is permit or deny. You can add set statement if you want to.
6 Replies 6
Harold Ritter
You can do that using a route-map. You will need to replace the current prefix-list filters with a route-map, as follow:
router bgp 100
neighbor <uplink1 address> route-map uplink1 out
neighbor <uplink2 address> route-map uplink2 out
route-map uplink1 permit 10
match ip address prefix-list <prefix-list name you currently use>
match community 1
route-map uplink1 deny 20
match community 2
route-map uplink1 permit 30
route-map uplink2 permit 10
match community 2
route-map uplink2 deny 20
match community 1
route-map uplink2 permit 30
ip community-list 1 permit 100:1
ip community-list 2 permit 100:2
If the prefix match both the prefix-list and community 100:1, it will be sent only to uplink1
If the prefix match both the prefix-list and community 100:2, it will be sent only to uplink2
If the prefix only match the prefix-list, it will be sent to both uplink1 and uplink2.
Also he need
1- ip bgp new format <- global mode
2- neighbor x.x.x.x send-community both <- under bgp of neighbor inject community
MHM
Hi @MHM Cisco World ,
The configuration I recommended will work without this command. I agree though that it makes it easier to read the community value (100:1 instead of 6553601).
Obviously, this technique will not work if the customer doesn't send the required communities.
Send commumity define of left side IBGP neighbors
Only on route-map match ip prefix-list and match community
no action define ????
