QOS - Output queueing feature not supported
bruno.trombim
Hello guys,
i am upgrading the router from 1900 to C1101-4P line and facing some QOS issue, when i try to set the service-policy in the tunnel 204 and 298 the following message is showed:
Output queueing feature not supported on vlan1020
config
class-map match-any class-map-noshape-cam
match access-group name acl-noshape-cam
class-map match-any class-map-qos-priority
match access-group name acl-qos-priority
policy-map policy-map-qos-priority
class class-map-qos-priority
bandwidth percent 80
class class-default
fair-queue
random-detect
policy-map qosswtelecom-priority
class class-map-noshape-cam
police 9500000 conform-action transmit exceed-action drop
class class-default
shape average 4725000
service-policy policy-map-qos-priority
policy-map qosmpls-priority
class class-default
shape average 950000
interface Tunnel204
description Primary tun to Loja4
bandwidth 512
ip unnumbered GigabitEthernet0/0/0.6
ip mtu 1400
ip tcp adjust-mss 1360
ip ospf cost 40
qos pre-classify
keepalive 10 3
tunnel source GigabitEthernet0/0/0.6
tunnel mode ipsec ipv4
tunnel destination 172.30.x.x
tunnel protection ipsec profile SDM_Profile1
interface Tunnel298
description Primary tun to ADM
bandwidth 512
ip mtu 1400
ip ospf cost 40
qos pre-classify
keepalive 10 3
interface Tunnel304
description Secondary tun to Loja4
bandwidth 512
ip unnumbered GigabitEthernet0/0/0.7
ip mtu 1340
ip tcp adjust-mss 1300
ip ospf cost 60
qos pre-classify
keepalive 10 3
tunnel source GigabitEthernet0/0/0.7
tunnel destination 189.108.x.x
service-policy output qosswtelecom-priority
interface Tunnel398
description Secondary tun to ADM
bandwidth 512
ip mtu 1340
ip ospf cost 60
qos pre-classify
keepalive 10 3
tunnel destination 187.9.x.x
balaji.bandi
Can you post show version output.
Do you have QoS config on the Physical Interface where VPN Terminates ?
BB
hello,
sorry for being late to answer.
Do you mean in the other side where this vpn will be tunelled ?
R14#sh version
Cisco IOS XE Software, Version 16.09.04
Cisco IOS Software [Fuji], ISR Software
(ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.4, RELEASE SOFTWARE
(fc2)
lsharrah
I have same issue.  Does cisco router C1111-8P running c1100-universalk9_ias.16.09.05.SPA.bin even support service policies on vlan's?
as i remember it should support, can you post the configuration  ?
have you checked the configuration guide ?
BB
