Bookmark
Subscribe
2747
ping 8000 bytes in size not making it
Brent Rockburn
Level 2
Level 2
Is there any way to let this size of packet go through on an interface.
when I ping and make the packet 8000 it fails.
Any advice would be great
8 Replies 8
paolo bevilacqua
What's the point ? That is like sending 4 packet and an half as fragments, and expect the router to reassemble them, thing that it never does or is expected to do. Only ping to larger MTU and if you're really in an pinging mood, use sweeping sizes.
Mohamad Qayoom
Level 3
Level 3
You can configure MTU size on the interface.
e.g.
mtu 9216
That will fail on numerous types of interface that don't support large MTU, like frame-relay, ethernet, and many others.
"That will fail on numerous types of interface that don't support large MTU, like frame-relay, ethernet, and many others."
I like to know where you get this information from. This is a 9000 bytes
ping across a Cisco 7140 router:
[Expert@P1-NGx]# ping -s 9000 -c 5 98.174.21.130
PING 98.174.21.130 (98.174.21.130) 9000(9028) bytes of data.
9008 bytes from 98.174.21.130: icmp_seq=0 ttl=255 time=7.49 ms
9008 bytes from 98.174.21.130: icmp_seq=1 ttl=255 time=7.47 ms
9008 bytes from 98.174.21.130: icmp_seq=2 ttl=255 time=7.52 ms
9008 bytes from 98.174.21.130: icmp_seq=3 ttl=255 time=6.37 ms
9008 bytes from 98.174.21.130: icmp_seq=4 ttl=255 time=6.36 ms
--- 98.174.21.130 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4042ms
rtt min/avg/max/mdev = 6.366/7.045/7.522/0.563 ms, pipe 2
[Expert@P1-NGx]#
I was responding to the suggestion of setting an arbitrary larger MTU on the interface, it is not possible to do so, hence the command fails.
With regard to the ability of the router of reassembling ping packets, your 7140 appears to do that well, other platforms /IOS could not, yet that does not indicate a problem whatsoever.
It works on the C3640 platforms as well.
The ping goes across the Cisco 3640 and
7140 and it still works:
C3640#ping 98.174.21.134 source f1/0 size 9000 repeat 10
Sending 10, 9000-byte ICMP Echos to 98.174.21.134, timeout is 2 seconds:
Packet sent with a source address of 129.174.1.2
Success rate is 100 percent (10/10), round-trip min/avg/max = 12/14/20 ms
C3640#
Mohamed Sobair
Level 7
Level 7
Ping with 8000 byte packet size causes a router to fragments the packets.
The default MTU on Cisco router interface is 1500, The Fragmentation can cause delays, and if the delay is larger than 2 seconds (default time out) you will see . instead of !
This doesnt necessarily means the packet is not transmitted at all, it just means there is no reply within those 2 seconds.
Mohamed
Good point, but to fail due to timeout, the interface must be really, really slow.
More likely the failure is due to some internal buffer that is insufficient.
