05-07-2014 12:28 AM - edited 03-04-2019 10:55 PM
when I am ping to google I cannot reach mtu morethan 1500... Is it possible to ping through internet with an MTU more than 1500??
Solved! Go to Solution.
05-07-2014 04:37 AM
Normally when DF bit is not set and if the egress MTU is less, the rotuer will fragment the packet. So in your case, it should still reach your destination.
I did a quick try with size of 1501 and I get reply from google.com.
You can try to ping your ISP nexthop with the size and see if it works. Is it working when you do a ping from your default GW to nexthop/google site?.
-Nagendra
05-07-2014 01:31 AM
are doing ping with do not fragment bit set and size 1500 byte? If so consider that when you send a packet bigger then max admitted MTU over the path, the packet must be fragmented; if you are using the "do not fragment" bit the packet will be discarded and an ICMP Can't Fragment Error packet is generated (type 3 (destination unreachable), code 4 (fragmentation needed but don't-fragment bit set).
If you specify size 1500 the real size of the packet is more then 1500 due to ICMP header
Bye,
enrico
PS please rate if useful
05-07-2014 01:39 AM
I am pinging without DF bit set .... I can ping inside my network with MTU more than 1500 also, but it is not possible wen I am trying to ping some IPs over internet
05-07-2014 04:37 AM
-Nagendra
05-07-2014 06:00 AM
Assuming you mean packet size (not MTU which is a characteristic of network segment) I suppose some appliance in the network infrastructure will drop fragmented packet but it's strange. Try debug ip icmp to see which is the device that discard your packets.
05-07-2014 11:51 PM
Thank you all for your reply ...... actually I found the issue is from our upstream service provider ... it working wen I was trying through a different service service provider
