pinging tool
mukthar786
dear sir,
can anyone suggest pinging software to ping 80 address & status.
please suggest
rajinikanth
Level 3
Level 3
Check this link
http://www.netmon.org/tools.htm
They are plenty to choose from
Raj
gpulos
Level 8
Level 8
try http://www.solarwinds.com
many very nice, useful tools including the multi ping you're looking for.
you could also probably write a perl script to do this if you have the ability. not hard if you know perl.
desai.jaideep
Level 5
Level 5
I would recommend DUDE from www.mikrotik.com
JD
First there was "Big Brother" then there is Hobbit. Big Brother is now a commercial product, but folks that were involved in its creation have now created "Hobbit" which is open source. It is a simple interface for quick monitoring of numerous devices by pings, snmp, DNS query and others via a web based interface. The response times can be fed into "larrd" to give graphs as well. Used both likem both give it a run.
http://hobbitmon.sourceforge.net/docs/about.html
Brian
