POINT TO POINT TUNNEL
atul.kumar323
Hi guys,
First time here
i am having trouble with the point to point tunnel that i configured on the two routers
When i do sh ip int brief, tunnel on the both routers is whowing up but i am not able to ping the destination ip adddresses on the both router and lan ips
don't know where i am going wrong
interface Tunnel0
bandwidth 1000
ip address 10.2.0.1 255.255.255.252
ip virtual-reassembly
ip tcp adjust-mss 1460
tunnel source FastEthernet4.4090
tunnel destination 172.17.3.140
interface Tunnel0
description Tunnel to Auckland HO (CHEMAK1)
bandwidth 1000
ip address 10.2.0.2 255.255.255.252
tunnel source Dialer0
tunnel destination 172.23.2.206
chemak2m001#ping 172.17.2.206
Sending 5, 100-byte ICMP Echos to 172.17.2.206, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CHEMAK1R001#ping 172.17.3.140
Sending 5, 100-byte ICMP Echos to 172.17.3.140, timeout is 2 seconds:
Please help
Atul
9 Replies 9
Ali Norouzi
1- Add Keepalive command under the interface tunnel. keepalive 5 2 is ok. After timer expires it will show you if the tunnel is realy up o not.
2- Ping the tunnel destination with IP of tunnel source as source of the ping. It will show you that the path status.
hi Ali, thanks for the reply.
I did keepalive 5 2 and that made the tunnel protocol down.
still going throug the pain
Hi Atul,
Yiu can ping the tunnel ip address......(In ur case: 10.2.0.1 or 2), and you can not ping the provider ip address.
If you want to test the tunnel then try to ping tunnel ip address.
one more command to test tunnel:
test int tunnel 0
REgards
please rate if it helps.
Hi Sandeep,
Cant ping the tunnel ip address as well.
i used this command test int tunnel 0
chemak2m001# test int tu0
... Failed - not connected problem
1 interfaces: 0 passed, 1 failed, 0 skipped, 0 untestable
Can you paste the output of this coomand: sh int tunnel0 from both end.
Or just configure like this:
interface Tunnel1
desc bandwidth 1000
ip mtu 1300
ip tcp adjust-mss 1260
tunnel source xxx.xxx.xxx.xxx
tunnel destination xxx.xxx.xxx.xxx
means reduce the tcp adjust value .
If still not works then please paste the whole config of routers.(To get the whole overview)
Please rate if it helps.
Hi Sandeep,
As soon as i have removed the keep alive from the tunnel interface, tunnel come back up
and when i run this test int tu0 command, it give me the following result
CHEMAK1R001#test in tu0
!!!!!!!!!!!!!!!!!!!! Passed
1 interfaces: 1 passed, 0 failed, 0 skipped, 0 untestable
It means your tunnel is working.....
try to ping your tunnel ip address??
still can't ping the tunnel ip address 10.2.0.1 or 10.2.0.2.
even if the test command is showing me pass
can you paste the config of the interface ???
step1: just check with your provide(Is the ip address from provider is online.)
if still fails then please paste ur whole config.
