07-31-2012 05:49 AM - edited 03-04-2019 05:07 PM
I’m testing a 1841 with 2 WIC-1ADSL cards, but the connections are dropping every 30-50mins. If I swap the cars out for HWIC-1ADSL’s then the lines are stable. I’ve had the profiles on the lines dropped the 4mb down and 512k up but I’m still getting the same issue.
I’ve tried a few 1841’s with various IOS’s and different WIC’s but still get the same result.
Has any one seen this before or know how I can go about trouble shooting it?
Brasso
07-31-2012 06:12 AM
The WIC cards are of an older generation, not having all the features needed for today's circuits.
As you have found out, you should only use HWIC ADSL instead.
07-31-2012 06:30 AM
Thanks for the answer, but ADSL2+ should support legacy devices and thus the WIC-1ADSL should be stable. They do work and they do get good throughput its just the disconnect every so often.
I’ll do some more digging.
