Policing is not working
sivakondalarao
We have 3550 switch with following IOS information.
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(19)EA1a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 09-Dec-03 03:21 by yenanh
Image text-base: 0x00003000, data-base: 0x0080DDAC
ROM: Bootstrap program is C3550 boot loader
IN_BLR_RT_L301 uptime is 1 year, 43 weeks, 1 day, 11 hours, 12 minutes
System restarted at 21:54:05 IST Tue Nov 2 2004
System image file is "flash:c3550-i5q3l2-mz.121-19.EA1a.bin"
cisco WS-C3550-48 (PowerPC) processor (revision E0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0636Y0SU
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0A:B7:D2:2F:00
Motherboard assembly number: 73-5701-06
Power supply part number: 34-0967-01
Motherboard serial number: CAT063401T1
Power supply serial number: DCA06341KTF
Model revision number: E0
Motherboard revision number: D0
Model number: WS-C3550-48-EMI
System serial number: CAT0636Y0SU
Configuration register is 0x10F
We implemented policing with below configuration:
access-list 160 permit ip host 10.140.17.135 host 10.132.17.24
class-map match-any test1
match access-group 160
policy-map test1
class test1
police 8000 8000 exceed-action drop
interface FastEthernet0/16
switchport mode dynamic desirable
no ip address
service-policy input test1
we kept continues ping to 10.132.17.24 from 10.140.17.135 with payload 60000bytes.
After applying policy-map to interface also it is pinging.
Is there any configuration problem or it is not supported in our device?
Required help in this.......
SKRAO
9 Replies 9
cisconoval
From your post what I understood is you want to block the host 10.132.17.24 by accessing the 10.140.17.135. am I correct?
If so you had menitoned "permit" in your policy. Just change it to "deny". Also give "access-list 160 permit ip any any"
at the last.
If you wanna block only the Ping / ICMP then give the follwoing access-list
access-list 160 deny icmp host 10.140.17.135 host 10.132.17.24
Hope it will help you.
My requirement is to not block the ICMP.
Just I wanted to restrict it to particular bandwidth.
SKRAO
jj-zhou
i think perhaps you should enable ip cef.
rajinikanth
Level 3
Level 3
Your Payload for ping is 60000 Bytes
Where as the syntax of police in rate-bps is in bits per seconds (bps)
Syntax:
police [exceed-action {drop | policed-dscp-transmit}]
So you need to change your command then it should work properly,
Eg:
police 80000 8000 exceed-action drop
Hope this solves your problem
rajinikanth,
as per your context it should not be ping bcz of the exceed payload. But sivakondalarao says still he can able to ping? Am I correct?
Yes! your correct !
But he wants to ping still 8000 payload
The access-list with icmp denies both echo reply and request.
yes you are right
SKRAO
rajinikanth
Level 3
Level 3
First is your Fa 0/16 is a egress interface ,if yes then
You cannot use the service-policy interface configuration command to attach policy maps that contain these elements to an egress interface:
Access control list (ACL) classification.
Per-port per-VLAN classification.
rajinikanth
Level 3
Level 3
policy-map test1
class test1
set ip dscp 10
Instead of this command
Use this
match ip dscp 10
Hope it works, tell me if it worked.
