policy based route on 3750
ladan.eftetahi
thanks for your attention. I config policy-based route on 3750 just like this :
no aaa new-model
switch 1 provision ws-c3750-24ts
vtp domain vtp-a
vtp mode transparent
ip subnet-zero
ip routing
ip dhcp pool vlan1
network 192.168.0.0 255.255.255.0
default-router 192.168.0.244
--More-- ip dhcp pool vlan2
network 20.20.20.0 255.255.255.0
default-router 20.20.20.1
ip dhcp pool vlan3
network 172.31.131.0 255.255.255.240
default-router 172.31.131.1
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
name test
vlan 3
name Arian
--More-- !
interface FastEthernet1/0/1
switchport mode access
spanning-tree portfast
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
--More-- !
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
switchport access vlan 2
interface FastEthernet1/0/11
interface FastEthernet1/0/12
--More-- spanning-tree portfast
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
--More-- interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
switchport access vlan 3
interface FastEthernet1/0/23
duplex half
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
--More-- !
interface GigabitEthernet1/0/2
interface Vlan1
ip address 192.168.0.244 255.255.255.0
interface Vlan2
ip address 20.20.20.1 255.255.255.0
ip policy route-map pbr
interface Vlan3
ip address 172.31.131.1 255.255.255.240
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.2
ip http server
access-list 10 permit 20.20.20.0 0.0.0.255
route-map pbr permit 10
match ip address 10
set ip next-hop 172.31.131.14
--More-- !
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
I want to ping 20.20.20.1 from my pc with 20.20.20.2 ip address ,& ping 172.31.131.14 or 172.31.131.14 ,but I can't .if my pc be in vlan 2 with 20.20.20.1 default gateway, I should to ping 20.20.20.1 but
I can't.what's the problem. if I want to route vlan 2 to next-hop 172.31.131.14
,I can't never access to vlan 1 or vlan 3 networks despite the fact that with enaqble ip routing in 3750 i expect that I can run intervlan routing.
could you pls guid me.
thanks
Edison Ortiz
What port is the PC using ? Currently you have the following ports assigned to VLAN2
Can you post the show interface output from the port where the workstation is connected to ?
Also, post the 'show int vlan 2' ?
pdervaux
Isn?t very clear what you would like to do!
In your case the ACL 10 define the interesting traffic used by PBR.
All packets with address 20.20.20.x are forwarded to the 172.31.131.14 IP address.
Is this device aware how to reach the 20.20.20.0/24 network?
In your case is probably better to have an extended access-list with source AND destination IP address defining the packets forwarded to the 172.31.131.14 address.
Pascal
