Cisco 871-K9 URL Filtering
AndrisKri
I'm have Cisco 871-K9
SDM version: 2.3
IOS version: 12.4(6)T2
In the URL Filtering section router says:
Application Firewall unavailable.
The IOS image in your router does not support the requested feature. To configure the feature, you need to go to the Software Center on Cisco.com and upgrade your IOS image to one that supports thyis feature set. URL Filtering
Any idea what to do.
Thank you in advance.
Andris
5 Replies 5
desai.jaideep
Level 5
Level 5
Can you give the IOS name?It should me advipservicesk9, but just making sure.....
JD
spremkumar
Level 9
Level 9
Hi Andris
Are you running your box with the following ios code c870-advipservicesk9-mz.12.4-6.T.bin ?
Do confirm the exact ios code name which is there in your box out there..
regds
AndrisKri
So,
IOS Image Name: 0-advsecurityk9-mz.124-6.T2.bin
Andris
hi Andris
As per the feature navigator the ios code which you are currently having in your box support URL web filtering.
Though i am not sure about SDM can you try configuring up the same using CLI ?
This link can help you out doing the same through CLI..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122y/122yu11/ftwebsen.htm
regds
This IOS supports firewall feature, but this will be done through external software called Websense...Are you having that software?
http://www.websense.com/
And the config can be done using following Link:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b0e.html
Pls rate helpful posts.
JD
