Policy Based Routing Based on DSCP Values
witani
I am a situation where I need to policy route traffic based on dscp values, but I could not find the feature enabled on my IOS
c7200p-advipservicesk9-mz.124-4.XD5.bin or even on c7200p-advipservicesk9-mz.150-1.M2.bin.
Any one knows if this is supported on Cisco routers in the first place?
Wael
Edison Ortiz
I haven't tested but this should work
access-list 101 permit ip any any dscp (value)
route-map PBR-DSCP
match ip address 101
set ip next-hop x.x.x.x
Edison
Hi Edison,
I am having one query on this solution, as I am also going to implement the same in my network.
Can i configure this way?
Example:
access-list 101 permit ip any any dscp cs1
                       permit ip 192.1.1.0/24 192.2.2.0/24
Explanation:
if DSCP marking devide is on traffic will initiate from 192.168.1.2 with dscp value cs1.
if DSCP marking device id down traffic will initiate from 192.168.1.0 without dscp value.
Query:
Can we create fail-over in this scinario?
Fail over condition will be - if packets are comming with Marking with cs1, it should follow "permit ip any any dscp cs1".
If packets are comming without dscp marking, it shoud follow, "permit ip 192.1.1.0/24 192.2.2.0/24".
Amol
Yes.
