Policy based routing on Cisco 2911 ISR
andy_4578
I have setup a basic PBR config to route Http and Https out of a different interface (fa0/0/0) but for some reason http traffic is still going out of the Gi0/1 interface.
Is anyone able to see whats wrong?
Config attached minus the crypto stuff and the publics have been changed.
2 Accepted Solutions
There is no need to take out the route-maps with the 'no' commands.
You can just edit the existing route-maps:
route-map SDM_RMAP_1 permit 1
match ip address 101
match int gi0/1
route-map SDM_RMAP_2 permit 2
match int fa0/0/0
Obviously there's a need for caution since the nat statements are in place and could potentially break things
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi Andy,
My bad I gave you a wrong command for the NAT overload route-maps, you have to match the outgoing interface not the next-hop so that the traffic is correctly natted depending which outgoing interface it is using.
match interface g0/1
match interface f0/0
doing these changes should not affect your access to the router as it is for natted traffic which is transit traffic but it will affect your end users of course.
Also your PBR is ok with the set ip next-hop, if you use the set ip default next-hop then it will use that next-hop only if there is no explicit route for the destination in the routing table( it won't consider a default route as an explicit entry).
Alain
17 Replies 17
cadet alain
can you try this:
no route-map SDM_RMAP_1
no route-map SDM_RMAP_2
  match ip next-hop 94.1.1.1
route-map SDM_RMAP_2 permit 1
match ip next-hop 192.168.200.253
Alain
Just tried using "set interface fa0/0/0" and they lost all http/https traffic so i've put it back to "set ip next-hop 192.168.200.253"
I can see hits on the route map acl..
soleshow route-map HTTP
route-map HTTP, permit, sequence 10
  Match clauses:
    ip address (access-lists): HTTP
  Set clauses:
    interface FastEthernet0/0/0
  Policy routing matches: 418868 packets, 130677567 bytes
gw1ja#
But if i go to website www.whatismyip.com  i still see the public IP of interface gi0/1
The default route pointing to interface gi0/1 has to be there otherwise all traffic stops
Hi Alain,
I can try that, trouble is im about 5000 miles away from the router and removing the route-maps will drop the internet and my connection.
I should be able to try it later when the users have gone home i'll use the "reload in" command incase anything goes wrong
Cheers
Andy
Bilal Nawaz
route-map HTTP permit 10
match ip address HTTP
set ip default next-hop 192.168.200.253
default next-hop: Sets next hop to which to route the packet if there is no explicit route for this destination.
Try this and see if this works, you have a default route towards gi0/1 which may be the cause for traffic still being routed that way. Not saying to take your default out.
Hi Bilal,
Just tried changing to set ip default next-hop 192.168.200.253 but the traffic still seems to go out via the gi0/1 interface.
The odd thing is doing an internet speed test the traffic seems to go out via the gi0/1 interface and come back via the fa0/0/0 the reason i say that is because gi0/1 is on a 4mb lease line and fa0/0/0 is a 40mb adsl line, the return traffic shows as 36mb
If that makes any sense
Cheers
did you try what I suggested above ?
Alain
match int gi0/1
match int fa0/0/0
Cheers for your help guys. I will try the above at 3pm GMT, the router is in Dubai so the users will have left for the day at 3 my time then if i break it no one will no.
Just tried ...
Still going out of the wrong interface unfortunatley
Hi Andy,
Alain
When you had the option:
How did you do your tests? Did you do a speed test and whatismyip? Could you explain what the results were please?
Thank you
The config is currently like this...
If i do a speed test i get 4mb down and 20/30 up which doesnt make any sense
If i go to what is my IP i see the public address of gi0/1
Hi Andy,
Just a query - what are your nat statements purposing?
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/1 overload
ip nat inside source route-map SDM_RMAP_2 interface FastEthernet0/0/0 overload
Hi Bilal,
Not sure what you mean? both NAT statements are to do dynamic nat for the inside traffic out to the internet.
If i remove them nothing will get out.
Andy
