Stumped - 871W home network config. pages not loading?
kcabramson
Hi i have a really simple home network setup using the Cisco 871W 4-Port 10/100 Wireless G Router (CISCO871W-G-A-K9). I can't figure out for the life of me what is going on. Web pages seem to "half load" sometimes (netflix, facebook, bank of america doesn't load at all, etc). It doesn't always happen. Sometimes the pages will load fine. I have tested with multiple computers so I know that it is the router itself. Below is my configuration. Please ignore anything regarding the wifi. I know that isn't set up correctly. I'll deal with that later. I wanted to see if i was missing anything. Config is really basic. Attached is what one of the "half loading" web pages looks like
version 12.4
no service pad
hostname MyRouter
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 blahblahblahblah
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
crypto pki trustpoint TP-self-signed-1608398951
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1608398951
revocation-check none
rsakeypair TP-self-signed-1608398951
crypto pki certificate chain TP-self-signed-1608398951
certificate self-signed 01
  ZX82X252 ZX82X1BB AXXZX2X1 X2X2X1X1 ZXXDX6X9 2A864886 F7XDX1X1 X4X5XXZX
  Z1Z12FZX 2DX6XZ55 X4XZ1Z26 494F5Z2D 5Z656C66 2D5Z6967 6E65642D 4Z657274
  6966696Z 6174652D Z1Z6ZXZ8 ZZZ9Z8Z9 Z5Z1ZX1E 17XDZXZ2 ZXZZZXZ1 ZXZ1Z4Z2
  ZXZZ5A17 XDZ2ZXZX Z1ZXZ1ZX ZXZXZXZX ZX5AZXZ1 Z12FZX2D X6XZ55X4 XZ1Z2649
  4F5Z2D5Z 656C662D 5Z69676E 65642D4Z 65727469 66696Z61 74652DZ1 Z6ZXZ8ZZ
  Z9Z8Z9Z5 Z1ZX819F ZXXDX6X9 2A864886 F7XDX1X1 X1X5XXXZ 818DXXZX 8189X281
  81XXB9FX ZCEB6492 27Z78Z9F BZ5C8ZEF 9EB81B52 FB4F1Z51 A5AC8B5E 5ZAXFXB8
  5911CCB9 EC5A22C1 5X98C2E8 ZCE17DED 121B224X 57B95C2C A4Z827Z7 4967FZ49
  8681456F 175668F9 AC12BA6B 19A55718 FBFZ2DA2 914C1CFF 88766ZA5 XA1AXEDF
  81DC49DC 4D2Z29F4 ZBZ69555 ZDZZ22X9 41DC6A57 X28ZD8B6 15ADB5F9 6F617FXE
  569FX2XZ X1XXX1AZ 7AZX78ZX XFX6XZ55 1D1ZX1X1 FFX4X5ZX XZX1X1FF ZX25X6XZ
  551D11X4 1EZX1C82 1A4B4Z69 7A7A6C65 4Z697Z6Z 6F2E6B6Z 697A7A6C 652E6C6F
  6Z616CZX 1FX6XZ55 1D2ZX418 ZX168X14 18FZ6CBZ 1DZ7F684 661ZE559 FF7CE7BX
  24DB22B4 ZX1DX6XZ 551DXEX4 16X41418 FZ6CBZ1D Z7F68466 1ZE559FF 7CE7BX24
  DB22B4ZX XDX6X92A 864886F7 XDX1X1X4 X5XXXZ81 81XX28Z5 8CC9Z7AB 4D49DB5Z
  AZBDXCBX E2E6A8CE 27CCZ9AB 52C469EA 45C5B2Z6 68X82572 72AX1C58 F6C4D76B
  2A21E4X6 1E5BC585 72ZEX9B6 2917D89F 95DZXFE5 FCDXF428 ACC7ZZ44 Z4E2CDZE
  8EXFB92A 6E26F29A B6778B4Z 5ACB1946 D826AEF6 8EZ96X7A X6B6AEA2 X7CXACZ7
  X6E2C98X D76DZ588 CF55D966 94X2745C XAXCAF65 ED71
            quit
dot11 syslog
dot11 ssid MyWiFi
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 blahblahblahblhabhab
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 1.1.2.1 1.1.2.99
ip dhcp pool 1.1.2.0/24
   network 1.1.2.0 255.255.255.0
   default-router 1.1.2.1
   dns-server 1.1.2.5
   lease 7
ip domain name mydomain.local
ip host desktop 1.1.2.14
ip name-server 1.1.2.5
username admin privilege 15 secret 5 blahblahblahblah
archive
log config
  hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description INTERNET WAN PORT
mac-address 0000.1111.2222
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
description Built-in Atheros miniPCI
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no dot11 extension aironet
encryption mode ciphers aes-ccm
broadcast-key change 3600
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2412
station-role root
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 1.1.2.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list ACL-NAT interface FastEthernet4 overload
ip access-list extended ACL-NAT
permit ip 1.1.2.0 0.0.0.255 any
no cdp run
control-plane
banner motd
# My Router
# GET THE F OUT.
# Unauthorized Access Is Prohibited!!!
# Love,
# Me
line con 0
exec-timeout 30 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 20 0
privilege level 15
password blahblah
logging synchronous
transport input telnet ssh
scheduler max-task-time 5000
end
paolo bevilacqua
Wrong forum, post in "infrastructure - WAN and routing". You can move your post using the actions panel on the right.
paolo bevilacqua
thank you friend
kcabramson
I'm an idiot. It's related to my dinky domain server i setup at the exact same time
