Policy Based Routing with NAT
ovieira
Hi!
I have a router CS1750 on wich i'm trying to implement PBR with NAT. I can't seem to have it working because the ip traffic flows always for the same output interface. I'm trying to test a real situation where one can have 2 Internet links (Frame-Relay and ADSL) and i want to have the email traffic (POP3 and SMTP) going trought the Frame-relay link and the rest (http, ftp, p2p...) through the ADSL link.
Heres's the configuration:
hostname CS1750
ip cef
interface FastEthernet0
ip address 192.168.10.254 255.255.255.0
ip nat inside
ip policy route-map PBR
interface Serial0
description *** FRAME-RELAY - 250Kbps ***
ip nat outside
encapsulation frame-relay
ip route-cache policy
no fair-queue
interface Serial0.1 point-to-point
ip address 10.10.20.1 255.255.255.252
ip nat outside
frame-relay interface-dlci 16
interface Serial1
description *** HDLC - 2Mbps ***
ip address 10.10.10.1 255.255.255.252
ip nat outside
no fair-queue
ip nat inside source route-map NAT-ADSL interface Serial1 overload
ip nat inside source route-map NAT-FR interface Serial0.1 overload
ip classless
ip access-list extended ADSL
permit icmp 192.168.10.0 0.0.0.255 any
permit ip any any
remark *** All Traffic ***
ip access-list extended FR
permit tcp 192.168.10.0 0.0.0.255 any eq smtp
permit tcp 192.168.10.0 0.0.0.255 any eq pop3
remark *** Email Traffic (SMTP e POP3) ***
route-map PBR permit 10
match ip address FR
set interface Serial0.1
route-map PBR permit 20
match ip address ADSL
set interface Serial1
route-map PBR permit 30
set default interface Null0
route-map NAT-FR permit 10
match ip address FR
route-map NAT-ADSL permit 10
Thanks for your attention.
Regards.
14 Replies 14
Harold Ritter
Make sure that the ADSL ACL denies traffic that is allowed in the FR ACL. Otherwise "permit ip any any" will match all traffic, which will cause some traffic to go out via serial0.1 but with a natted source address of serial1. Your ACL should look like this:
deny tcp 192.168.10.0 0.0.0.255 any eq smtp
deny tcp 192.168.10.0 0.0.0.255 any eq pop3
permit ip any any
Hope this helps,
Hi!
Thanks for your answer. I've tried that already and with success. The problem I have now is that I want my solution to be redundant and if one of the Internet links goes down all traffic should go trough the other link. With the ACL you mentioned that can't happen.
Regards.
Hi Ovieira,
I do not think that is possible becase NAT fall back is not possible. As you must be having 2 different ISPs so Nat will be different for 2 interfaces and that is kinda not possible.
It would have been possible if you have 2 routers and you run HSRP between the ethernet lan links terminate one ISP on one router and another ISp on another router.
Ankur
Hi!
I don't think this is NAT fallback. I want first to decide wich internet link to use, using PBR, and then do NAT that is configured for that output interface.
Thanks.
You PBR says that traffic soming from this source for particualr port number moves out interface x for suppose and if that interface goes does there is no ACL saying it falls back to other interface so its a kinda PBR fallback and also NAT fallback because if the first interface goes down PBT as well as NAT should work for another interface which I think is not possible on a single router.
Ankur
here the ACL does the following
1; IF permit no action is taken
2: if deny then the packets are routed as per the Policy routing settings
thus you need to define the ACL in such a way that packets that need to use the PBR are denied and rest are permitted
thanks
Hi!
What ACL are you refering to? I have a Cisco document that says that the router first deals with PBR and then NAT. So, after the router decides witch link to use for output packets, NAT sould be applyed acourding to the output interface, rifgt?
Regards.
kumar here
Please try the method that I send to you before.
Instead of permit please us deny
it has to work
Hi Kumar!
Please confirm me what ACL are you refering.
Thanks.
I think he's talking about this:
permit ip any any
Since you have permit ip any any on ADSL, your pop3/smtp traffic will also hit this ADSL ACL. Clearly defining the ACLs for PBR/NAT will be convenience to your future troubleshooting and it's a very common & recommended practice.
So what you need will be:
permit ip any any
remark *** OTHER Traffic ***
this one,
only ICMP packets will be redirected
deny icmp 192.168.10.0 0.0.0.255 any
permit ip any any
will only redirect smtp and pop3
alfredshum
try to use "match interface" for the NAT:
match interface s0.1
match interface s1
For your PBR, you need to set a secondary interface
match ip address FR
set interface Serial0.1 Serial1
set interface Serial1 Serial0.1
But I doubt the PBR will work when the FR cloud has problems and your interface link status is still up.
And please also follow kumar's suggestion to change your ACLs accordingly.
kamlesh_s1181
Hi friend,
here is the config from Jeff Doyle for load balancing and redundency with two ISP's for diagram read the Jeff Doyle 2
interface Ethernet0
ip address 10.1.1.1 255.255.255.0
ip nat inside
interface Ethernet1
ip address 10.5.1.1 255.255.255.0
ip nat inside
interface Serial1
no ip address
interface Serial1.708 point-to-point
description PVC to ISP1
ip address 205.113.49.253 255.255.255.252
ip nat outside
frame-relay interface-dlci 708
interface Serial1.709 point-to-point
description PVC to ISP2
ip address 207.36.65.253 255.255.255.252
ip nat outside
frame-relay interface-dlci 709
router ospf 10
network 10.0.0.0 0.255.255.255 area 10
default-information originate always
router bgp 451
neighbor 205.113.49.254 remote-as 1135
neighbor 207.36.65.254 remote-as 216
ip nat pool ISP1 205.113.50.1 205.113.51.254 prefix-length 23
ip nat pool ISP2 207.36.76.1 207.36.77.254 prefix-length 23
ip nat inside source route-map ISP1_MAP pool ISP1
ip nat inside source route-map ISP2_MAP pool ISP2
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 2 permit 207.36.65.254
route-map ISP1_MAP permit 10
match ip address 1
match interface Serial1.708
route-map ISP2_MAP permit 10
match ip address 1
match ip next-hop 2
