Bookmark
Subscribe
2548
Policy-map question
Patrick McHenry
Level 4
Level 4
I'm trying to resolve an issue with phones on remote routers thet keep re-registering throughout the day. I changed the:
policy-map shaper
class class-default
    shape average 2000000
  service-policy voice_and_video
To:
policy-map shaper
class class-default
    shape average 8000000
Not sure what I have just done but it didn't break it. The Comcast bandwidth is atleast 8000000 so, I figured I would match it with this.
What does this command effect?
Thanks, Pat.
20 Replies 20
John is it possible that the CIR could be less than 2mbs on a Business line? What am I losing by making my shaper less than the CIR? If the CIR is 4mbs up and I set my CIR to 2, I am limiting the router, correct? So if the line is 10 up and 3 down, what would be the right setting for the shaper?
sh processes cpu | i 5
PID Runtime(uS)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   2      148000       59092          2  0.00%  0.00%  0.00%   0 Load Meter
   4   341420000       44956       7594  0.00%  0.13%  0.11%   0 Check heaps
   5        4000          15        266  0.00%  0.00%  0.00%   0 Pool Manager
  10   178504000        4923      36259  0.00%  0.07%  0.05%   0 Licensing Auto U
  14      128000       59059          2  0.00%  0.00%  0.00%   0 IPC Service NonC
  15       44000      288521          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  16       32000      288521          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  19        8000       59093          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  24   438248000     3137588        139  0.15%  0.17%  0.16%   0 ARP Input
  25      204000      307739          0  0.00%  0.00%  0.00%   0 ARP Background
  35           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  37       32000      295457          0  0.00%  0.00%  0.00%   0 GraphIt
  42     4984000      105003         47  0.00%  0.00%  0.00%   0 Net Background
  45      256000      295277          0  0.00%  0.00%  0.00%   0 TTY Background
  46     2816000      295468          9  0.00%  0.01%  0.00%   0 Per-Second Jobs
  50           0           2          0  0.00%  0.00%  0.00%   0 AggMgr Process
  51      452000      149102          3  0.00%  0.00%  0.00%   0 Fast Throttle Ti
  52           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  53           0           2          0  0.00%  0.00%  0.00%   0 Transport Port A
  54     3224000       61354         52  0.00%  0.00%  0.00%   0 HC Counter Timer
  55           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  56           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  57           0           2          0  0.00%  0.00%  0.00%   0 AUX
  58           0           2          0  0.00%  0.00%  0.00%   0 LED Timers
  59      212000           4      53000  0.00%  0.00%  0.00%   0 ESWPPM
  62      556000        2715        204  0.00%  0.00%  0.00%   0 i2c console redi
  63       16000      295443          0  0.00%  0.00%  0.00%   0 Console redirect
  65     3868000      105627         36  0.00%  0.00%  0.00%   0 OSPF-1 Hello
  68       60000      295469          0  0.00%  0.00%  0.00%   0 Crypto Device Up
  71      216000         436        495  0.00%  0.00%  0.00%   0 crypto engine pr
  75  2364548000      488426       4841  1.27%  1.28%  1.27%   0 ILPM
  82       36000      288512          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
  84      116000      295279          0  0.07%  0.00%  0.00%   0 PI MATM Aging Pr
  85           0          16          0  0.00%  0.00%  0.00%   0 AAA Server
  89     6992000       44727        156  0.00%  0.00%  0.00%   0 CDP Protocol
  95           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
  96      864000     9215542          0  0.07%  0.07%  0.07%   0 IPAM Manager
  98        4000          57         70  0.00%  0.00%  0.00%   0 IP ARP Adjacency
100    52900000      265318        199  0.23%  0.10%  0.02%   0 IP Input
101           0          57          0  0.00%  0.00%  0.00%   0 ICMP event handl
105           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
107      256000        9411         27  0.00%  0.00%  0.00%   0 CRYPTO IKMP IPC
111      208000     1154167          0  0.07%  0.01%  0.00%   0 SSS Feature Time
112     4888000      333058         14  0.07%  0.02%  0.00%   0 Spanning Tree
113           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
115           0           1          0  0.00%  0.00%  0.00%   0 AC Switch
116           0         985          0  0.00%  0.00%  0.00%   0 Authentication P
121      164000        5734         28  0.00%  0.00%  0.00%   0 CEF background p
125           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
130        4000         458          8  0.00%  0.00%  0.00%   0 TCP Timer
131           0          15          0  0.00%  0.00%  0.00%   0 TCP Protocols
133        4000         985          4  0.00%  0.00%  0.00%   0 HTTP CORE
135       36000        4931          7  0.00%  0.00%  0.00%   0 IP Background
137      188000          85       2211  0.00%  0.00%  0.00%   0 IP RIB Update
145           0          13          0  0.00%  0.00%  0.00%   0 Collection proce
150           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
151           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
152           0           1          0  0.00%  0.00%  0.00%   0 MQC Flow Event B
153     6424000    72783522          0  0.47%  0.48%  0.45%   0 HQF Shaper Backg
154           0           3          0  0.00%  0.00%  0.00%   0 RBSCP Background
155        4000           3       1333  0.00%  0.00%  0.00%   0 SCTP Main Proces
156           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
157           0           1          0  0.00%  0.00%  0.00%   0 IPS Process
158           0           2          0  0.00%  0.00%  0.00%   0 IPS Auto Update
159           0           2          0  0.00%  0.00%  0.00%   0 SDEE Management
160       44000      577004          0  0.00%  0.00%  0.00%   0 Inspect process
163       36000      577004          0  0.00%  0.00%  0.00%   0 CCE DP URLF cach
165           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
171           0           1          0  0.00%  0.00%  0.00%   0 X.25 Background
175           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
178       36000         457         78  0.00%  0.00%  0.00%   0 LOCAL AAA
183      444000        2960        150  0.00%  0.00%  0.00%   0 Crypto Support
185           0           4          0  0.00%  0.00%  0.00%   0 Crypto CA
188    85644000        6211      13789  0.00%  0.11%  0.21%   0 crypto sw pk pro
191    15732000       35340        445  0.00%  0.00%  0.00%   0 Crypto IKMP
193      340000       15655         21  0.00%  0.00%  0.00%   0 IPSEC key engine
195        4000          34        117  0.00%  0.00%  0.00%   0 Crypto ACL
202       32000      180795          0  0.00%  0.00%  0.00%   0 PM Callback
205        4000           3       1333  0.00%  0.00%  0.00%   0 EEM ED Resource
207       36000       29529          1  0.00%  0.00%  0.00%   0 RMON Recycle Pro
215        4000         101         39  0.00%  0.00%  0.00%   0 EEM Server
225           0           2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
234        8000         146         54  0.00%  0.00%  0.00%   0 Syslog
235           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
236     1540000     9230593          0  0.15%  0.12%  0.10%   0 PPP manager
237      920000     9230598          0  0.00%  0.06%  0.07%   0 PPP Events
238       12000      295450          0  0.00%  0.00%  0.00%   0 Multilink PPP
242      964000       59094         16  0.00%  0.00%  0.00%   0 Compute load avg
245           0           2          0  0.00%  0.00%  0.00%   0 Key Proc
250       56000        4923         11  0.00%  0.00%  0.00%   0 DFS flush period
251           0         167          0  0.00%  0.00%  0.00%   0 SSH Event handle
252       72000         428        168  0.00%  0.00%  0.00%   0 DHCPD Receive
253     2660000     2958941          0  0.07%  0.05%  0.04%   0 IGMP Input
254     3948000     6148381          0  0.15%  0.12%  0.09%   0 PIM Process
255      932000     2954526          0  0.00%  0.02%  0.01%   0 Mwheel Process
256        4000        4937          0  0.00%  0.00%  0.00%   0 MRIB Trans
257           0           4          0  0.00%  0.00%  0.00%   0 MFIB_cable
258     2388000    14742727          0  0.15%  0.15%  0.15%   0 MFIB_mrib_write
259        4000          10        400  0.00%  0.00%  0.00%   0 MFIB_mrib_read
261     1844000       38528         47  0.00%  0.00%  0.00%   0 NHRP
262        8000          85         94  0.00%  0.00%  0.00%   0 Tunnel Security
264      188000      295291          0  0.00%  0.00%  0.00%   0 DHCP Client
266       60000      577009          0  0.07%  0.00%  0.00%   0 IP NAT Ager
275           0           2          0  0.00%  0.00%  0.00%   0 SNMP Traps
Pat,
You'll need to spell out the word "five" for the show command to get the right output "sho proc cpu | inc five"
Probably not, but it's best if you find the actual rate.
You are limiting the router when shaping, but you're also somewhat protecting your traffic from being dropped at the PE router. Down speeds are generally higher than the up speed from most providers (I've never seen one the opposite direction, but I guess it could be possible). In your scenario, if you had 3Mb down/10Mb up, and you had a fastethernet connection of 100Mb, you'd want to shape your traffic to 10Mb (10000000).
HTH, John *** Please rate all useful posts ***
No, it is 10 down and 3 up. I Screwed up. Knowing that, would I still want to shape 10000000?
So if it is 3 up, shouldn't I be shaping 3, as the shaping is done in the outgoing direction(Ithink) and that would be the upload direction correct?
sh proce cpu | i five
CPU utilization for five seconds: 8%/3%; one minute: 9%; five minutes: 8%
CPU utilization for five seconds: 9%/3%; one minute: 9%; five minutes: 8%
shproce cpu | i five
Thanks, Pat
CPU utilization looks fine. I would shape to 3Mb since that's the cir and you'll get the full amount that you're paying for. Can you post the actual policy from the router?
Here it is with 3000000:
policy-map voice_and_video
class call_setup
    bandwidth 32
class internetwork_control
    bandwidth 32
class voice
    priority 128
class video
    priority 460
class class-default
policy-map shaper
class class-default
    shape average 3000000
policy-map mark_incoming_traffic
class discover_voip
  set dscp ef
class discover_signaling
  set dscp cs3
class discover_video
  set dscp cs2
class non_voip
  set dscp default
Thanks, Pat.
Pat,
One thing that I see is that your video is in the priority class along with your voice. This usually isn't recommended because there's only 1 LLQ. You can put multiple types of traffic in the queue, but in reality the video and voice will share the single LLQ. The problem with this is when someone is watching a video that's classified by this, the queue can get filled with video and then phones will fall behind in the queue and quite possibly be dropped or at least create latency. I would recommend taking your video out of the LLQ and create a bandwidth statement for it instead.
HTH,
John
