Port channel configuration
ncnaveen_arasu
Hi we have cisco 6500 series switch and configured port channel on both switches with 2 gig interfaces on both switches.
When we enable the port channel mode to as desirable to the interfaces on both side and applied the port channel to physical interfaces switch will go down and if we remove on any one side switch will come up. we have enabled globally the following commands,
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause unicast-flood
fabric buffer-reserve queue
Please sugest to make the port channel up
10 Replies 10
shine pothen
Level 3
Level 3
In order for EtherChannel to work,
1.the ports that are involved must have consistent configurations.
2.The ports must have the same VLAN
3.the same trunk mode
4.the same speed
5. the same duplex, and so on.
Most of the configuration differences within a switch are caught and reported when you create the channel. If one switch is configured for EtherChannel and the other switch is not configured for EtherChannel, the spanning tree process can shut down the channeled ports on the side that is configured for EtherChannel.
Spanning Tree Protocol (STP) on the switch where the EtherChannel is turned on thinks that there is a loop. This puts the channeling ports in the errdisabled state.
Try this out and let me know
Also post
Sh ether channel summary
Sh interface "interface type and numbe r" status
And config of etherchanel
Hi thanks for the reply, i have tried ur suuggested configuration but still port channel is down
please see the required details
On Switch A
interface Port-channel21
description *** NEW6509A to NEW6509B ***
switchport
switchport trunk allowed vlan 8-13,32-37,40,41,121-127,137,225,257,308-313
switchport trunk allowed vlan add 321-325,335-337,339,340,436
switchport mode trunk
no ip address
end
interface GigabitEthernet1/2
description *** To NEW6509B-G1/3 ***
switchport
switchport trunk allowed vlan 8-13,32-37,40,41,121-127,137,138,140,225,240,257
switchport trunk allowed vlan add 308-313,321-325,335-337,339,340,436
no ip address
channel-protocol pagp
channel-group 21 mode desirable
show etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
21     Po21(SD)        PAgP      Gi1/2(s)   Gi1/3(s)
Switch B
description *** NEW6509B to NEW6509A ***
switchport
no ip address
end
description *** To NEW6509A-G1/2 ***
switchport
no ip address
end
21     Po21(SD)         -
HI kindly suuggest
on the switch B how many physical interface are group to portchannel 21.
Check whether the physical ports on switch A and B are in up state.
sh int giga1/2.
please let me know the result.
try to add native vlan  and them try out on both ends
switchport trunk native vlan
FYI...
protocol pagp has much higher overhead compare to lacp. Cisco got rid of channel porotocol pagp on their newer switches.
So stick with lacp.
Are these switches are on same vtp domain ? If you answer yes, then remove this: errdisable recovery cause bpduguard
Rizwan Rafeek
yes its in same vtp domain, do i need to remove on both sides, wont it create STP loops
Yes you need to remove from the both switches.
"wont it create STP loops" Answer is no.
I have four 6500 switches running. Two switches on same VTP domain and other two are on separate domain without “errdisable recovery cause bpduguard” enabling globally.
If you fear of layer2 loops in fully mesh topology then enable “spanning-tree bpduguard enable” on the connecting interface. I believe it is enable by default.
Another due diligent on interfaces:
Spanning-tree guard loop.
Spanning-tree guard root
I hope you are running HSRP for each vlan common to both switches.
Thanks Peter for correction over what is going away.
Hi Rizwan,
This is a completely new and so far unconfirmed information to me.
  1. What makes you say that PAgP support is dropped? My experience is quite the contrary - the PAgP seems still to be supported on the newest IOS version for Catalysts 2960/3560, and for the VSS system and active-active detection, Cisco even introduced an improved version of PAgP called PAgP+. So they're not dropping PAgP, on the contrary, they are extending it.
  2. What makes you say that PAgP has much higher overhead? Is there any document that deals with PAgP message sizes, their frequency, and compares them to LACP? Both PAgP and LACP are fairly quiet protocols and in stable network operation, they generate very little trafic.
Are you perhaps confusing the trunking protocols ISL and 802.1Q with PAgP and LACP? It is namely true that ISL has much bigger overhead over 802.1Q, and it is true that support for ISL is gradually declining.
Best regards,
Peter
On Switch A
end
21     Po21(SD)         -
HI kindly suuggest
This is the reason why:  Your interfaces (both sides) have VLAN 138 as allowed but your PortChannel DOES NOT HAVE VLAN 138 allowed.
Rip out the ether channel (no int po 21) and in the interface, remove the  "channel-group 21 mode desirable" and put it back in.
