port-channel lcap fast-switchover command not available on the router
danielchau
We are trying to setup port-channel with redundancy 1:1 with our 6509 router,  but we found that we cannot use the command: lacp fast-switchover
Router(config-if)#lacp ?
  max-bundle  LACP maximum number of ports to bundle in this port channel
Router#sh ver
IOS (tm) s222_rp Software (s222_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 25-Sep-09 01:32 by ccai
Image text-base: 0x40101040, data-base: 0x42C80C10
Is this because this version dont have the nesserary command?
Daniel
Steve Fuller
Level 9
Level 9
Hi Daniel,
For the Catalyst 6500 the lacp fast-switchover command was not introduced until 12.2SXH. From the Understanding LACP 1:1 Redundancy section of the Catalyst 6500 Release 12.2SX Software Configuration Guide:
"Understanding LACP 1:1 Redundancy
With Release 12.2(33)SXH and later releases, the LACP 1:1 redundancy feature provides an EtherChannel configuration with one active link and fast switchover to a hot standby link."
It would be worth you considering a IOS upgrade anyway as 12.2SXF reached End of Support since Feb-2015. See End-of-Sale and End-of-Life Announcement for the Cisco IOS Software Release 12.2(18)SXF for the Cisco Catalyst 6500 Series.
Hi Steve,
So if i have a 7600 Series Supervisor Engine 2 card with 6509, i am not possible to run it ?
I checked here seems the latest firmware is SXF
https://software.cisco.com/download/release.html?mdfid=282201759&catid=268437717&rellifecycle=ED&release=12.2.18-SXF17&softwareid=280805680&sortparam=
Daniel
Hi Daniel,
Apologies I missed the fact you were running a Supervisor Engine 2. Unfortunately that SE is not shown as supported in the 12.2SXH release notes so this feature will not be available to you.
