Port-channel Member | EC-5-MINLINKS_MET
TrivialPants
Hi All,
I have an ASR 903 that I am running 16.12.5 on and I only have logs showing that the port-channel has a member taken out and then added back. It is a two-port port-channel (20Gbps LAG). There is no min-links config on the port-channel.
Has anyone else encountered this? I have read some bug reports that just show it may indicate a high amount of traffic, however there was not a large influx of traffic that I can gather. https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn37237?rfs=iqvred
Here is the log message that I received:
TenGigabitEthernet0/0/8 taken out of port-channel1
%EC-5-MINLINKS_MET: Port-channel Port-channel2 is up as its bundled ports (2) meets min-links
TenGigabitEthernet0/0/8 added as member-2 to port-channel2
balaji.bandi
not sure how is your config : ( check below may help you )
https://www.cisco.com/c/en/us/support/docs/routers/asr-903-series-aggregation-services-routers/116116-troubleshoot-asr-evc-config.html
I have seen some bug on 16.9.X somehow not able to view the bug fully
CSCvh67059
ASR903 detected %EC-5-MINLINKS_NOTMET more earlier.
BB
