Port Forwarding
Translator
Community Manager
Community Manager
Dear all good afternoon,
I need to port forwarding with NAT but not from a single port, but from a set of ports, specifically from port 10000 to 10250, this is possible.
Thank you very much.
Waiting for your comments.
5 Replies 5
Translator
Community Manager
Community Manager
what is the device model you are trying to configure?
Good luck
KB
Cisco 1841.
Hello
Yes you can,
I assume you are using domain nat ( inside/outside)
Can you clarify if this is to be static or dynamic, using a single pubic ip address or specific public ip addressing?
Example:
ip access-list extended NATACL
permit tcp any any range 10000 10250
route-map STAN
match ip address NATACL
ip nat inside source static 10.1.123.1  1.1.1.1 route-map STAN
Kind Regards
Paul
Translator
Community Manager
Community Manager
greetings @fernandomoreno777523023 thanks for communicating with the Cisco community, the device you are referring to is a ASA, or a router ?
We'd like to know what device it is to be able to help you.
