Port Redirection: Traffic redirection from WAN to LAN on CISCO 4321 Router
Reza_Mohd
I'm looking for help on port redirection as traffic coming on WAN interface should redirect to another LAN IP on another port. I'm using CISCO 4321 router.
e.g: WAN IP: 1.1.1.1
       LAN IP: 10.10.10.10:443
Any help will be highly appreciated.
Reza
Hello
First of all are you using network translation between your LAN/WAN?
res
Paul
Kind Regards
Paul
Paul has already told you the solution: NAT.
First, specify your outside port as outside and inside as inside:
int gi 0/0
ip nat outside
description "ISP Uplink - WAN"
ip address 1.1.1.2 255.255.255.248
int gi 0/1
ip nat inside
description "Internal Network - LAN"
ip address 10.10.10.1 255.255.255.0
Now, if I'm reading this right, you are assuming that all traffic coming into 10.10.10.10 should be forwarded to 443? This will likely need another appliance, and the internet generally won't pass through much of anything beyond 80, 443, 25, etc. through a browser, so NAT can be simple:
ip nat inside source static 10.10.10.10 1.1.1.1
Translating ports is something I have zero experience with, so if this is what you're looking for I'm out. :-)
On a side note, if you just want to redirect TCP port 443, use the statement below:
ip nat inside source static tcp 10.10.10.10 443 1.1.1.1 443 extendable
Deepak Kumar
You didn't mention that WAN Port number. So I am assuming that your WAN port number as 8000. Means you are trying to access your internal Server from the outside with below URL
https://1.1.1.1:8000
and your internal server is working on 443
So your DNAT configuration will:
ip nat inside source static TCP 10.10.10.10 443 1.1.1.1 8000 extendable
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
