port traffic
vishalpatil86
hi,
i have cisco 2960. One user is connected to fa0/15 and browsing the internet.
i want to c how much traffic is incoming and outgoing. how can i do this?
2 Accepted Solutions
Show int fa0/15 should atleast show last 5 minute input / output rate in bits/second on that interface.
Adding to Kristian,
You can also change the default timer of 5 minutes. Use command "load-interval X" where X are seconds in interface configuration mode.
Example hot to change it to 30 sec:
conf t
int fa0/15
load 30
end
show int fa0/15
FastEthernet0/15 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0012.437e.3f08 (bia 0012.437e.3f08)
  MTU 9000 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 301129
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 seconds input rate 264000 bits/sec, 158 packets/sec      <======= In rate
  30 seonds output rate 3987000 bits/sec, 648 packets/sec      <======= Out rate
     187451816 packets input, 42715889911 bytes, 0 no buffer
     Received 2159938 broadcasts (1771426 multicasts)
     0 watchdog, 1771426 multicast, 0 pause input
     992415764 packets output, 576069827154 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
Nik
HTH,
Niko
11 Replies 11
shehinpm1
#sh interface fa0/15 cmd out put wl give lots of information.
hi,
there is one command which shows how much user traffic is generating currently...
Hi Vishal,
That is "show ip accounting"
Please rate the helpful posts.
Naidu.
hi Latchum,
this is the output-
sw#sh int gig6/7 accounting
GigabitEthernet6/7
                Protocol    Pkts In   Chars In   Pkts Out  Chars Out
           Spanning Tree          0          0     909841   54590460
                     CDP      30343   11803427      30344   14504432
now how can i read this??
Hi Vishal,
use only show ip accounting the output will be like below... In which you can find the source and destination and the bandwidth usage in Bytes.
lpar561#sh ip accounting
   Source      Destination     Packets     Bytes
   10.10.10.2       192.168.0.0     3352         4657488
Naidu.
hi,
i dont get anything after giving sh ip accounting command
Use show interface summary .  .  If you need port utilization you can use sh controllers utilization .
thank you glen,
but i want the output as send/receive format. can i do see that with the help of command?
Adding to Kristian,
conf t
int fa0/15
load 30
end
show int fa0/15
  Keepalive not set
Nik
HTH,
Niko
thats awsum,
thanks kristian and nik..... this is wat i wanted. thank u
