PPP authentication
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-16-2007 09:14 AM - edited 03-03-2019 05:28 PM
Hi Experts,
If i have two routers (point-to-point), one of them configured with ppp authentication CHAP and the other configured with ppp authentication PAP , the line protocol will be down or up ?
Ibrahim Alwahidi
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2007 10:06 AM
Hi Ibrahim,
The PPP link won't come up unless the authentication succeeds (both sides must support either PAP or CHAP simultaneously):
Troubleshooting PPP (CHAP or PAP) Authentication
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a00800b4130.shtml
HTH, please do rate all helpful replies,
Mohammed Mahmoud,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2007 10:54 AM
It will be up.
Router 1
username R2 password CISCO
int s0/0
en ppp
ppp authentication chap
ppp pap sent-username R1 password CISCO
Router 2
int s0/0
en ppp
ppp authentication pap
ppp chap hostname R2
ppp chap password CISCO
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2007 12:38 PM
Hi Edison,
You are absolutely correct, the case you are suggesting shall work, as R2 requires any PPP initiated to it to be PAP (ppp authentication pap) authenticated and since R1 can authenticate itself using PAP it will succeed and vice versa for R1 with CHAP (ppp authentication chap), i guessed that the original poster's question involved that each side is only configured with one different method as in and out.
HTH,
Mohammed Mahmoud.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2007 01:58 PM
Thanx Edison,
But i want to ask u another question about that can i put any username that i want for example
instead of using username R1 , i want to use username Linux...
Ibrahim Alwahidi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2007 04:01 PM
Then you need to create an username Linux on R2.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2007 09:11 PM
Hi Ibrahim,
Like Edison has said, you can change the username like you can on the calling router (the router initiating the session), but always keep in mind the router authenticating the other router (we'll call it the server) must have a local entry of this username in order to be able to authenticate the calling router with, as i've told you before on the other thread think of it as a client server issue.
HTH,
Mohammed Mahmoud.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2007 04:40 PM
Router 1
int s0/0
en ppp
ppp pap sent-username Linux password CISCO
Router 2
int s0/0
en ppp
