FIFO problem
thaershunnar
hi all,
i am getting this message on a 2600 router :
00:18:38: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/1 Rx FIFO Overflow
00:18:43: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
00:18:49: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
00:18:55: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
any body knows a fast solution ??
Richard Burts
Thaer
You have posted this same issue in this forum with the title: i need a quick help plesae. That post has received good advice to upgrade the version of code. If anyone has anything else to contribute on this topic I suggest that the discussion be consolidated in that thread.
Rick
Rick
Friend i think you are hitting this bug.
CSCdy78397
Externally found severe defect: Resolved (R)
AMDP2_FE-3-RXOVERFLO msg severely degrades performance on 2600
First fixed in versions: 12.2(12.10)T1 12.2(12.12)PI6 12.2(13.3)B 12.2(15)BW 12.2(15)BX 12.2(15)BZ 12.2(15)ZN
You may check the details of the bug on the following link:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdy78397&Submit=Search
There error messages appear when the FE interface on the 2600 is overdriven and it causes severe degradation. As the act of printing the message causes a feedback such that the maximum
frame rate is at least halved, this kind of feedback is unstable and causes a kind of severe disruption that could potentially make the system come to a standstill so you should consider an IOS upgrade to the latest image in 12.2T line or to the latest 12.3 mainline image.
Reducing the traffic on the interface until the message is no longer displayed is a possible workaround for this bug.
HTH, rate if it does
Narayan
