PPP Multilink with LLQ and AIM Hardware Compression
nceitil
Hello Guys,
Just wanted to check if anyone has managed to get this or similar working.
Will be trying a third version of code tonight (12-3-15). I have already tried 12-3-11T3 and 12-3-14T without success.
Here is a brief overview
2x 3725 Routers
One has WIC-2T modules and the other a NM-2CE1-T1-PRI
module.
The multilink is 2x E1
Each unit has a AIM-COMPR4.
I am using CBWFQ with a priority of 50% and burst a value.
The problem is a follows:
The minute I enable compression and it becomes active I loose ALL WAN connectivity. I can still telnet into the ethernet of the router on my local side. The QOS appears to be working. The sh compress commands tell me it's working and I get 2:1 ratios but all traffic is dead. I can't even ping the remote WAN IP address.
Have tried LZS,MPPC,STAC and Predictor.
Any ideas ???
Could you please post the configs?
Hello There,
No need to worry. It was the code. In fact I highly recommend staying away from 12.3.14T2 (Regardless of feature set). We started having random CPU spikes and only a hard boot would sort out the problem.
Loaded up 12.3.15 IP PLUS and it worked like a charm. Currently getting on average 2.8 to 1 ratio. Users still manage to push the 4Mb to the limit. No apparent additional latency. Running extensive testing this week.
This sounds ok!
A great relief and another IOS issue.
I would appreciate if you could post your config , we are trying to do the same thing. what compression method did you use?
any advice would be highly appreciated.
