pppoe-client command unavailable
1BWILLEMS
Hello, I'm trying to setup a pppoe-client config on an ASR1001 running asr1001-universalk9.03.02.01.S.151-1.S1.bin.
When I want to add the "pppoe-client dial-pool-number 1" under the ethernet interface, the command is not available.
Could this be linked to the IOS?
Deepak Kumar
I think you need a minimum Cisco IOS XE Release 3.5S for this feature. Here is the guide:ASR 1001.png
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/bbdsl/configuration/xe-3s/asr1000/bba-xe-3s-asr1000-book/bba-pppoe-client-xe.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
thx for the feedback. I'll try to upgrade and let you know
