PPPoE on an 831
mvoss
I have a remote facility with a DSL modem that can only do bridge mode, meaning all authentication with the ISP has to be done on the device behind it. I have the PPPoE username/password from the ISP and I'm wondering if it's possible to set up an 831 to do the authentication.
cristianlinca
Hello is this config working?
Yesterday I ran into an issue and my home router is broken so I have to configure my ISP connection on this old 831 CISCO Router. Did some searching online and got here.
Can you please tell if you managed to make it work?
In the command below, what is that 0 after password?
ppp pap sent-username username@isp.com password 0 password
shouldn't be only?
ppp pap sent-username "myISPusername" password "myISPpassword"
I will try tonight and let you know the results if I get no answer till then.
Cheers and thanks for the post, seems helpful
Cristian
this should be possible. Here is a sample configuration for the 831, replace the username and password with the ones you have from your ISP:
version 12.2
no service pad
hostname 831
logging queue-limit 100
ip subnet-zero
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LOCALPOOL
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description Inside private interface
ip nat inside
hold-queue 100 out
interface Ethernet1
description Connection to DSL Modem ISP
no ip address
ip tcp adjust-mss 1452
load-interval 30
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip http server
no ip http secure-server
access-list 1 permit 192.168.1.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
line con 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
scheduler max-task-time 5000
end
HTH,
GP
cristianlinca
shouldn't be only?
Cristian
the keyword 0 is inserted in the running config and it means that the following value is the unencrypted value.
Regards.
Alain
