3G Configuration on 819 Router [SOLVED]
_yzenezy_
I have a 819 Router (C819HG-U-K9) and I'm trying to get the 3G connection up. I have followed this thread which was a great help but so far I'm still unable to get a connection to my carrier:
https://supportforums.cisco.com/message/3824614#3824614
The 3G cell network seems to be ok:
#sh cell 0 network
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = HSPA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = AUS, Network = Optus
Mobile Country Code (MCC) = 505
Mobile Network Code (MNC) = 2
Location Area Code (LAC) = 33320
Routing Area Code (RAC) = 1
Cell ID = 38469
Primary Scrambling Code = 384
PLMN Selection = Automatic
Registered PLMN =  , Abbreviated =
Service Provider = YES OPTUS
I can even send and receive SMS's on the cell network.
Our carrier (Exetel) does not require a username/password so they are not set in the profile:
#show cellular 0 profile 1
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = exetel1
Authentication = None
Username:
Password:
* - Default profile
This is what I get when I attempt a manual start-chat:
#show debugging
General OS:
  Modem control/process activation debugging is on
PPP:
  PPP authentication debugging is on
  PPP protocol errors debugging is on
  PPP packet display debugging is on
Chat Scripts:
  Chat scripts activity debugging is on
#start-chat gsm 3
Jan 10 01:28:59.655: TTY0: resume timer type 1 (OK)
Jan 10 01:28:59.655: CHAT3: Matched chat script gsm to string gsm
Jan 10 01:28:59.655: CHAT3: Asserting DTR
Jan 10 01:28:59.655: CHAT3: Chat script gsm started
Jan 10 01:28:59.655: CHAT3: Sending string: AT!SCACT=1,1
Jan 10 01:28:59.655: CHAT3: Expecting string: OK
muddy#
Jan 10 01:29:10.835: Ce0 PPP: No remote authentication for call-in
Jan 10 01:29:10.835: CHAT3: Carrier drop expecting OK
Jan 10 01:29:10.835: CHAT3: Chat script gsm finished, status = Carrier dropped
Jan 10 01:29:10.835: TTY3: Line reset by "Exec"
Jan 10 01:29:10.835: TTY3: Modem: (unknown)->READY
Jan 10 01:29:10.835: TTY3: no timer type 0 to destroy
Jan 10 01:29:10.835: TTY3: no timer type 1 to destroy
Jan 10 01:29:10.835: TTY3: no timer type 3 to destroy
Jan 10 01:29:10.835: TTY3: no timer type 4 to destroy
Jan 10 01:29:10.835: TTY3: no timer type 10 to destroy
Jan 10 01:29:10.835: TTY3: no timer type 2 to destroy
Jan 10 01:29:11.835: Ce0 PPP: Using dialer call direction
Jan 10 01:29:11.835: Ce0 PPP: Treating connection as a callin
Jan 10 01:29:11.835: Ce0 PPP: Session handle[8F000019] Session id[345]
Jan 10 01:29:11.835: Ce0 PPP: No remote authentication for call-in
Jan 10 01:29:13.843: Ce0 PPP: No remote authentication for call-in
I've tried lots of different configuartions so I may have left something undone or done that shouldn't be. Have I overlooked something simple? Any assistance is apreciated.
Thanks in advance,
Tom
PS, Here's my config:
hostname muddy
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-2586860025
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2586860025
revocation-check none
rsakeypair TP-self-signed-2586860025
crypto pki certificate chain TP-self-signed-2586860025
certificate self-signed 01 nvram:IOS-Self-Sig#5.cer
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
license udi pid C819HG-U-K9 sn FGL164624V9
username xxxxxxxxxxxx privilege 15 secret 4 xxxxxxxxxxxxxxxxxxxxxxxx
controller Cellular 0
interface Cellular0
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 30
dialer string gsm
dialer-group 1
async mode interactive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE
PUBLICLY-KNOWN CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL
NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line 3
script dialer gsm
no exec
rxspeed 7200000
txspeed 5760000
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
9 Replies 9
_yzenezy_
Shameless bump on my part. Has anyone a few clues for me?
Hello Tom,
Try changing the encapsulation on your Cellular0 interface from ppp to slip, i.e.
interface Cell0
  encapsulation slip
The documentation appears to indicate that for the basic communication with the cellular controller, we need to speak plain serial data which is exactly the SLIP. Then please post the output of the debug again. Thank you!
Best regards,
Peter
Hi Peter,
Thanks for your reply.
I did try this before but got an unexpected response:
muddy#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
muddy(config)#interface cellular 0
muddy(config-if)#encapsulation slip
Cellular0: Only PPP encapsulation supported
muddy(config-if)#
Seems I can set slip on this interface. Any idea why? Is there some other configuration I need to make first?
I suppose this information is useful:
muddy#show inventory
NAME: "C819HG-U-K9 chassis", DESCR: "C819HG-U-K9 chassis"
PID: C819HG-U-K9       , VID: V01 , SN: FGL164624V9
NAME: "C819H Mother board on Slot 0", DESCR: "C819H Mother board"
PID: C819HG-U-K9       , VID: V01 , SN: FOC15244XUE
NAME: "Modem 0 on Cellular0", DESCR: "Sierra Wireless Mini Card MC8795V HSPA modem"
PID: 8795V             , VID: 1.0, SN: 354226045184705
Is this an HSPA+7 modem? Shoul I be using a different chat-script?
http://www.sierrawireless.com/en/productsandservices/AirPrime/Wireless_Modules/High-speed/MC8795V.aspx
Kind regards,
Tom
Ok,
I've worked out this is not an HSPA+ modem.
With the chat script:
chat-script gsm "" "ATDT*99*1#" TIMEOUT 60 "CONNECT"
It appears to make a connection but I get no IP Address:
muddy#show debugging
General OS:
PPP:
Chat Scripts:
muddy#
Jan 11 01:08:05.735: TTY0: resume timer type 1 (OK)
muddy#start-chat gsm 3
muddy#
Jan 11 01:08:15.927: TTY0: resume timer type 1 (OK)
Jan 11 01:08:15.927: CHAT3: Matched chat script gsm to string gsm
Jan 11 01:08:15.927: CHAT3: Asserting DTR
Jan 11 01:08:15.927: CHAT3: Chat script gsm started
Jan 11 01:08:15.927: CHAT3: Sending string: ATDT*99*1#
Jan 11 01:08:15.927: CHAT3: Expecting string: CONNECT
Jan 11 01:08:15.935: CHAT3: Completed match for expect: CONNECT
Jan 11 01:08:15.935: CHAT3: Chat script gsm finished, status = Success
muddy#show cellular 0 profile
PDP Type = IPv4
Username:
Password:
* - Default profile
Configured default profile for active SIM 0 is profile 1.
What is required to get the IP Address assigned?
Kind regards,
Tom
Current configuration : 5645 bytes
! Last configuration change at 01:06:32 UTC Fri Jan 11 2013 by cisco
! NVRAM config last updated at 00:29:22 UTC Fri Jan 11 2013
version 15.1
hostname muddy
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
interface Cellular0
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer-group 1
ppp ipcp dns request
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip http server
access-list 1 permit any
dialer-list 1 protocol ip list 1
no cdp run
control-plane
line con 0
login local
line aux 0
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
line vty 0 4
access-class 23 in
privilege level 15
login local
end
Well I seem to be making more progress but I'm still stuck. I remind you that my carrier expects an APN only; no username or password are expected. With some routing and a ping I see the following:
muddy#show cellular 0 profile 1
PDP Type = IPv4
Username:
Password:
* - Default profile
muddy#
PPP:
  PPP protocol negotiation debugging is on
Chat Scripts:
muddy#
muddy#ping 165.228.211.230
Sending 5, 100-byte ICMP Echos to 165.228.211.230, timeout is 2 seconds:
Jan 11 02:04:16.319: CHAT3: Attempting async line dialer script
Jan 11 02:04:16.319: CHAT3: Dialing using Modem script: gsm & System script: none
Jan 11 02:04:16.323: CHAT3: process started
Jan 11 02:04:16.323: CHAT3: Asserting DTR
Jan 11 02:04:16.323: CHAT3: Chat script gsm started
Jan 11 02:04:16.323: CHAT3: Sending string: ATDT*99*1#
Jan 11 02:04:16.323: CHAT3: Expecting string: CONNECT
Jan 11 02:04:16.335: CHAT3: Completed match for expect: CONNECT
Jan 11 02:04:16.335: CHAT3: Chat script gsm finished, status = Success.
Jan 11 02:04:18.379: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
Jan 11 02:04:18.379: Ce0 PPP: Sending cstate UP notification
Jan 11 02:04:18.379: Ce0 PPP: Processing CstateUp message
Jan 11 02:04:18.379: PPP: Alloc Context [ACFC74C]
Jan 11 02:04:18.379: ppp6 PPP: Phase is ESTABLISHING
Jan 11 02:04:18.379: Ce0 PPP: Using dialer call direction
Jan 11 02:04:18.379: Ce0 PPP: Treating connection as a callout
Jan 11 02:04:18.379: Ce0 PPP: Session handle[4000006] Session id[6]
Jan 11 02:04:18.379: Ce0 LCP: Event[OPEN] State[Initial to Starting]
Jan 11 02:04:18.379: Ce0 PPP: No remote authentication for call-out
Jan 11 02:04:18.379: Ce0 LCP: O CONFREQ [Starting] id 1 len 20
Jan 11 02:04:18.379: Ce0 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jan 11 02:04:18.379: Ce0 LCP:    MagicNumber 0x627795CA (0x0506627795CA)
Jan 11 02:04:18.379: Ce0 LCP:    PFC (0x0702)
Jan 11 02:04:18.379: Ce0 LCP:    ACFC (0x0802)
Jan 11 02:04:18.379: Ce0 LCP: Event[UP] State[Starting to REQsent]
Jan 11 02:04:18.387: Ce0 LCP: I CONFREQ [REQsent] id 12 len 25
Jan 11 02:04:18.387: Ce0 LCP:    ACCM 0x00000000 (0x020600000000)
Jan 11 02:04:18.387: Ce0 LCP:    AuthProto CHAP (0x0305C22305)
Jan 11 02:04:18.387: Ce0 LCP:    MagicNumber 0x9759A1DD (0x05069759A1DD)
Jan 11 02:04:18.387: Ce0 LCP:    PFC (0x0702)
Jan 11 02:04:18.387: Ce0 LCP:    ACFC (0x0802)
Jan 11 02:04:18.387: Ce0 LCP: O CONFACK [REQsent] id 12 len 25
Jan 11 02:04:18.387: Ce0 LCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
Jan 11 02:04:18.387: Ce0 LCP: I CONFACK [ACKsent] id 1 len 20
J.an 11 02:04:18.387: Ce0 LCP:    ACCM 0x000A0000 (0x0206000A0000)
Jan 11 02:04:18.387: Ce0 LCP:    MagicNumber 0x627795CA (0x0506627795CA)
Jan 11 02:04:18.387: Ce0 LCP: Event[Receive ConfAck] State[ACKsent to Open]
Jan 11 02:04:18.387: Ce0 PPP: Phase is AUTHENTICATING, by the peer
Jan 11 02:04:18.387: Ce0 LCP: State is Open
Jan 11 02:04:18.387: Ce0 CHAP: I CHALLENGE id 1 len 35 from "UMTS_CHAP_SRVR"
Jan 11 02:04:18.387: Ce0 CHAP: Unable to authenticate for peer
Jan 11 02:04:18.387: Ce0 PPP DISC: User failed CHAP authentication
Jan 11 02:04:18.387: PPP: NET STOP send to AAA.
Jan 11 02:04:18.387: Ce0 LCP: O TERMREQ [Open] id 2 len 4
Jan 11 02:04:18.387: Ce0 LCP: Event[CLOSE] State[Open to Closing]
Jan 11 02:04:18.387: Ce0 PPP: Phase is TERMINATING
Jan 11 02:04:18.395: Ce0 LCP: I TERMACK [Closing] id 2 len 4
Jan 11 02:04:18.395: Ce0 PPP: No remote authentication for call-out
Jan 11 02:04:18.395: Ce0 LCP: Event[Receive TermAck] State[Closing to Closed]
Jan 11 02:04:18.395: Ce0 LCP: Event[DOWN] State[Closed to Initial]
Jan 11 02:04:18.395: Ce0 PPP: Phase is DOWN
Jan 11 02:04:20.399: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
Jan 11 02:04:20.399: Ce0 PPP: Sending cstate DOWN notification
Jan 11 02:04:20.399: Ce0 PPP: Processing CstateDown message...
Success rate is 0 percent (0/5)
muddy#
Jan 11 02:04:25.443: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Jan 11 02:04:25.443: Ce0 PPP: Sending cstate DOWN notification
Jan 11 02:04:25.443: Ce0 PPP: Processing CstateDown message
It looks like it wants to connect but fails on CHAP. Any clues for a no username/password connection?
Tom
Here's my config:
hostname muddy
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
import all
lease 0 2
no ip domain lookup
no ipv6 cef
interface Cellular0
ip nat outside
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip nat inside
ip http server
ip nat inside source list 1 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
no cdp run
control-plane
line con 0
login local
line aux 0
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
line vty 0 4
access-class 23 in
privilege level 15
login local
end
Hi All,
I've worked out that the peer is looking for a username on my router called UMTS_CHAP_SRVR:
Configuring a username:
username UMTS_CHAP_SRVR
has done the trick!
This helped immensely:
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a00800b4130.shtml
Jan 11 03:48:13.043: Ce0 CHAP: I CHALLENGE id 1 len 35 from "UMTS_CHAP_SRVR"
Jan 11 03:48:13.043: Ce0 PPP: Sent CHAP SENDAUTH Request
Jan 11 03:48:13.043: Ce0 LCP: State is Open
Jan 11 03:48:13.043: Ce0 PPP: Received SENDAUTH Response PASS
Jan 11 03:48:13.043: Ce0 CHAP: Using hostname from configured hostname
Jan 11 03:48:13.043: Ce0 CHAP: Using password from AAA
Jan 11 03:48:13.043: Ce0 CHAP: O RESPONSE id 1 len 26 from "muddy"
Jan 11 03:48:13.043: Ce0 CHAP: I SUCCESS id 1 len 4
Jan 11 03:48:13.043: Ce0 PPP: Phase is FORWARDING, Attempting Forward
Jan 11 03:48:13.047: Ce0 PPP: Phase is ESTABLISHING, Finish LCP
Jan 11 03:48:13.047: Ce0 PPP: Phase is UP
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = my.static.ip.address
Username:
Password:
* - Default profile
#show cellular 0 connection
Data Transmitted = 936 bytes, Received = 936 bytes
Profile 1, Packet Session Status = ACTIVE
        IP address = my.static.ip.address
        Negotiated QOS Parameters:
        Precedence = Normal Priority, Delay = Class 3
        Reliability = Unack GTP, LLC, Ack RLC, Protected data
        Peak = 256 kB/sec, Mean = 50000 kB/hr
        Traffic Class = Interactive
        Uplink Max = 5760kbps, Guaranteed = Subscribed
        Downlink Max = 7.2Mbps, Guaranteed = Subscribed
        Max SDU size = 1500 bytes
        SDU error ratio = 1E-4, BER = 1E-5
Now, off to harden properly, build a tunnel and a few other tasks.
Thanks to Peter Paluch for his tip. Even though you didn't 'answer' my question, you gave me some focus. I would give you some credits if I knew how.
Thanks and I hope this helps someone else.
Kind regards,
Tom
I have same problem with HWIC-3G-GSM , my ISP dos not have username and password and I try
to change to encapsulation PPP to encapsulation slip , the router return error msg only PPP support ,
can you explain how you make encapsulation ppp without username and password ?
Thank you,
Best Regards
Hi Guys,
I had the same issue with a separate 3G module on 888G.
Thought to share as below worked for me,
cellular 0 gsm profile create 1 telstra.internet chap '' ''
chat-script INTERNET "" "ATDT*99*1#" TIMEOUT 30 "CONNECT"
interface Cellular0
 no ip address
 encapsulation ppp
 dialer in-band
 dialer pool-member 1
interface Dialer1
 encapsulation slip
 dialer pool 1
 dialer string INTERNET
 dialer persistent
ip route 0.0.0.0 0.0.0.0 Dialer1
line 3
 script dialer INTERNET
I`m posting this for future reference.
I encountered the same problem as _yzenezy_
Configuration was as follows:
chat-script DIAL "" "ATDT*99***1#" TIMEOUT 30 "CONNECT"
interface Cellular0
 ip mtu 1530
 ip nat outside
 encapsulation ppp
 dialer in-band
interface Dialer1
 mtu 1530
 ip nat outside
 encapsulation ppp
 load-interval 30
 dialer pool 1
 dialer idle-timeout 0 either
 dialer string DIAL
 dialer persistent delay initial 10
 dialer persistent delay 10
 dialer-group 1
 no cdp enable
dialer-list 1 protocol ip permit
line 3
script dialer DIAL
cellular 0 gsm profile create 1 MY_APN
There was no connection
debug ppp negotiation showed this
*Feb  6 06:56:37.903: Ce0 PPP: Phase is AUTHENTICATING, by the peer
*Feb  6 06:56:37.903: Ce0 CHAP: Redirect packet to Ce0
*Feb  6 06:56:37.903: Ce0 CHAP: I CHALLENGE id 1 len 35 from "UMTS_CHAP_SRVR"
*Feb  6 06:56:37.903: Ce0 LCP: State is Open
*Feb  6 06:56:37.903: Ce0 CHAP: Unable to authenticate for peer
*Feb  6 06:56:37.903: Ce0 PPP DISC: User failed CHAP authentication
I tried configuring hostname AND password on my dialer interface as _yzenezy_ said:
interface Dialer1
 ppp authentication chap callin
 ppp chap hostname UMTS_CHAP_SRVR
 ppp chap password 0 UMTS_CHAP_SRVR
Since the connection was unsuccessful, i continued with removing hostname and PAF it connected! So, the final config on my dialer interface is:
interface Dialer1
 mtu 1530
 ip nat outside
 encapsulation ppp
 load-interval 30
 dialer pool 1
 dialer string skripta
 dialer-group 1
 no cdp enable
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = 10.169.129.129
Access Point Name (APN) = MY_APN
Username:
Password:
Hope this helps someone out there!
Cheers,
Tom
