HI
I have configured PPTP in my router cisco 2901.
When I connect to to PPTP from my windows PC, I am getting internet connection. but I cant reach to the Remote networks connected to the firewall.
(Remote PC)======PPTPconnection ----Router-----Firewall(ASA)---192.168.100.20(Host)
But When I enable the "USE default Gateway on remote networks" then I lost my internet connection and can reach the remote networks(192.168.100.20)
Here are my config:
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
interface Tunnel1
ip address 10.12.10.1 255.255.255.252
tunnel source GigabitEthernet0/0
tunnel destination 49.0.43.50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description **WAN CONNECTION**
ip address 49.0.43.51 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description ** CONNECTED TO FIREWALL **
ip address 10.10.10.1 255.255.255.248
ip nat inside
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0
ip mtu 1400
ip nat inside
ip tcp adjust-mss 1360
peer default ip address pool PPTP-Pool
no keepalive
ppp encrypt mppe 128
ppp authentication ms-chap ms-chap-v2
interface Vlan1
no ip address
ip local pool PPTP-Pool 192.168.80.20 192.168.80.50
ip forward-protocol nd
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.250 88 49.0.43.52 88 extendable
ip nat inside source static 192.168.100.20 49.0.43.53
ip route 0.0.0.0 0.0.0.0 49.0.43.49
ip route 10.10.10.8 255.255.255.248 10.10.10.2
ip route 10.10.20.0 255.255.255.0 10.12.10.2
ip route 192.168.0.0 255.255.254.0 10.10.10.2
ip route 192.168.2.0 255.255.255.0 10.12.10.2
ip route 192.168.4.0 255.255.254.0 10.10.10.2
ip route 192.168.6.0 255.255.254.0 10.12.10.2
ip route 192.168.10.0 255.255.255.0 10.10.10.2
ip route 192.168.20.0 255.255.255.0 10.12.10.2
ip route 192.168.30.0 255.255.255.0 10.10.10.2
ip route 192.168.40.0 255.255.255.0 10.12.10.2
ip route 192.168.100.0 255.255.255.0 10.10.10.2--- My required Remote network (Server) which is under Firewall
access-list 10 permit 192.168.100.0 0.0.0.255
access-list 10 permit 192.168.4.0 0.0.1.255
access-list 10 permit 192.168.6.0 0.0.1.255
access-list 10 permit 192.168.10.0 0.0.0.255
access-list 10 permit 192.168.15.0 0.0.0.255
access-list 10 permit 192.168.20.0 0.0.1.255
access-list 10 permit 192.168.30.0 0.0.0.255
access-list 10 permit 192.168.0.0 0.0.1.255
access-list 10 permit 10.10.10.0 0.0.0.7
access-list 10 permit 10.10.10.8 0.0.0.7
access-list 10 permit 192.168.80.0 0.0.0.255 ------PPTP VPN POOL
Can someone please guide me to sovle the issue ?
I need both internet connection and reachability to other network(Server network 192.168.100.0/24) from my PPTP client PC.
Best Regards
ARIQ
Solved! Go to Solution.
the router configuration looks good now. What VPN client are you using ? 'Use default gateway on remote networks' should be disabled, but you might need to add a route to the remote networks locally, depending in your client, as described below:
Configuring Split-tunnel Client VPN
https://documentation.meraki.com/MX-Z/Client_VPN/Configuring_Split-tunnel_Client_VPN
you need to deny NAT for the VPN clients connecting to the server network, and allow all other traffic to be NATted. You cannot do that with a standard access list, you need the extended list below (assuming that your server network is 192.168.100.0/24):
ip nat inside source list 100 interface GigabitEthernet0/0 overload
access-list 100 remark Deny NAT for VPN Clients
access-list 100 deny ip 192.168.80.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 100 remark Allow NAT for VPN Clients
access-list 100 permit ip 192.168.80.0 0.0.0.255 any
HI
Im still facing the same problem.
When I enable the "USE default Gateway on remote networks"[VPN adapter settings] then I lost my internet connection and can reach the remote networks(192.168.100.20)
And when I disable the "USE default Gateway on remote networks" [VPN adapter settings] i get internet access but it disconnects the reach-ability to 192.168.100.0/24 networks .
Thank you in advance.
Note: Please let me know if you need full configuration.
did you remove this line from your configuration ?
HI,
Thanks for your quick response.
I didnt remove the line. I need this for my local LAN network's PAT
Do i have to remove the line ?
remove the line to check if that enables your VPN clients to access both the Internet and your servers. If that works, incorporate all the other lines into access list 100.
hello
Still Have the same problem.
I have deleted the line
checked and found that PPTP clients get internet but cant reach the remote network.
Please let me know what setting should i use in my PPTP Adapter ?
Should I enable "USE default Gateway on remote networks"
or
Disable "USE default Gateway on remote networks"
I have attached the configuration after deleting the line as you mentioned. please check the configuration file attached.
Thanks Its working right now.
i had to configure the below settings in my windows OS[cmd].
netsh interface ipv4 add route 192.168.100.0/24 "my-ppp-adapter_name"
I will post an update if I face any difficulties after this configuration.
Good to know that you got it resolved...
